What Formula Calculates the Force on a Mass by a Pole?
  • Thread starter Thread starter benhorris
To calculate the average force exerted by a pole on a mass, the kinetic energy (KE) of the mass must be determined using the formula KE = 0.5mv^2, resulting in 11,000 J for a 220 kg mass at 10 m/s. The work done by the pole, which equals the kinetic energy transferred, can be expressed as W = F * d, where d is the distance the pole is pushed into the ground (0.4 m). By rearranging the formula to solve for force (F), the average force is calculated as F = W/d, yielding 27,500 N. This demonstrates that the average force exerted by the pole on the mass is indeed 27 kN. The discussion highlights the importance of understanding the relationship between kinetic energy, work, and force in physics problems.
benhorris
Heres a question for you, can't work out what formula to use so i need some help.
A mass of 220KG, hits a cylindrical pole into the ground. Just before it hits the velocity of the mass is 10ms-1.
The pole is pushed 0.4 m into the ground, when the mass is droped 5m onto the pole. G = 9.8ms-2.
Show that the average force exerted by the pole on the mass is 27kN.
I just can't work it out! i know its simple but if someone can explain it to me id much appreciate it as I've spent nearly 30 mins on this one question and its only worth 2 marks..
Thanks in advance.
Ben.
Presumably there's no friction between the pole & the mass,so u'll have to assume that the force required will do work in pushing the pole.So the work done is equal to the KE transferred by the mass.
Daniel.
KE =0.5mv^2
hence 0.5x220x100 = 11000 J
? Now what - stuck on this Q and its very annoying...
Yes,but for a collinear force,the work is simply W=F*d...
Daniel.
Arnt i a numpty... hehe.
W=f*D
11000/0.4 =f
f =27500N
Duh, flippin ek. Always the simple ones that get me..
Thanks by the way. I am sure i have tested your intellectual capabilities to the utmost extreme levels. ...
Thanks once again.
Don't worry,i had the head-ache before looking over your problem...:-p It's just that now,i suddenly feel it more intensely...
Daniel.
P.S.OUCH!
