Mentor
- 50,920
- 26,950
jerromyjon said:So two launchers approach each other at relativistic velocity and as they pass one launches forwards and the other backwards parallel. They launch same acceleration?
Same acceleration relative to what?
If you mean the same proper acceleration, which in this scenario is equivalent to the coordinate acceleration in the rest frame of each launcher, if that's the way the launchers are set up, and you have stipulated that they are, then yes. The proper acceleration is determined by the actual thrust felt by the objects being launched, and you have stipulated that that's the same for both launchers. Since each object starts out at rest relative to the launcher that launches it, each object's coordinate acceleration in the rest frame of its launcher will be the same as its proper acceleration.
If you mean coordinate acceleration in a particular frame, then of course the coordinate acceleration of the object launched by launcher #2, in launcher #1's rest frame, will be different than the coordinate acceleration of the object launched by launcher #1, in launcher #1's rest frame. The coordinate acceleration of the two objects will also be different in launcher #2's rest frame. If you work it out, it turns out that the same will be true in any frame.
None of this has anything to do with whether there is such a thing as absolute motion or not, so I'm still not sure why you're asking about it.
