What Happens to Gravity and Temperature at the Center of a Black Hole?
The discussion revolves around the nature of gravity and temperature at the center of a black hole, exploring theoretical implications, the concept of singularities, and the behavior of matter and energy in extreme gravitational fields. Participants also touch upon the concept of absolute zero and its measurement.
  • Some participants propose that at the center of a uniform sphere, the net gravitational force would be zero, leading to a state of weightlessness.
  • Others argue that a human could not survive the conditions near a black hole's center due to tidal forces, which would rip them apart before reaching the singularity.
  • There is a suggestion that the laws of physics break down at the singularity, making it difficult to ascertain what happens there.
  • Some participants question the existence of a center in a black hole, with claims that a black hole has no center of mass.
  • Others clarify that a singularity, while having zero size, does have a center of mass.
  • There is a debate about whether a photon can exist at the singularity and how time behaves in that region.
  • Some participants express skepticism about the idea that a singularity could be traversable under certain conditions.
  • There are discussions about the implications of gravitational time dilation and the nature of light and images related to black holes.
Participants express multiple competing views regarding the nature of gravity and temperature at the center of a black hole, the existence of a center, and the survivability of matter near a singularity. The discussion remains unresolved with no consensus reached.
Participants highlight limitations in understanding the behavior of matter and energy at singularities, the dependence on definitions of mass and size, and the unresolved nature of gravitational effects at extreme conditions.
cragar
if u were at the center of a black hole which way would the gravity pull u. if it pulled u at all.
what do u guys think.
Another question is temperature relative . like if i had something on Earth near absolute zero
but relative to the sun its kinetic energy would be different.
And how do scientist's know were absolute zero is if they can't get to it how do they know its not further than they think.
Astronomy news on Phys.org
If you are at the center of a uniform sphere of any density, the net gravitational force on you would be 0. That is because the force due to the mass in any direction is canceled by equal force in exactly the opposite direction.
As far as absolute 0 is concerned, it is not to difficult to measure the volume of a fixed amount of gas at two different temperatures (at the same pressure), determine the linear function (PV= NRT) giving those two points and then solve for the T that makes V= 0.
so then would u be weightless.
Not really. If you could keep your body's proportions and that the black hole is larger than your body, the center of the black hole if it has a center is inside your body, then only one millimeter apart from the center of the black hole would be attracted toward the center of the black hole. It is of course a totally impossible scenario.
y is this an impossible scenario , what if a photon was at the center.
Since no matter can actually exist at the singularity, the question is irrelevant. For any living organism, the tidal forces alone would rip it to shreds long before contact with the centre.
edit: Oops, Cragar... I just realized that this might have been taken as a response to your last post. Not so; it was aimed at the original.
I was talking about a human into a black hole. I don't know enough Physics :frown: to answer your question, but I know that a human wouldn't survive, wouldn't conserve its proportions and I believe a black hole is smaller than a human body, but I'm not sure of the later.
they have super massive black holes that are like 10^6 times bigger than our sun.
can a photon exist at the singularity?
And how would time behave at the singularity taking gravitational time dialtion into effect
Careful.
They are 10^6 times more massive than our sun.
but certainly large enough for a photon to be in the center.
Simply put, the laws of physics as we know them break down at the singularity. We do not know what happens there. This is the only meaningful answer to your question.
ok thanks for your answer
cragar, you might want to take a look at rotating black holes.
You mean a black hole or the singularity? A black hole: the more mass it has, the more space it takes up (I think you mean how much space it takes up). For example, a black hole with the mass of our sun would be about 2 miles in radius. A typical black hole has a ten solar mass, and therefore a radius of about 12.5 miles. A million solar mass black hole (like at the center of a galaxy) would have a radius of 2,000,000 miles.
A singularity: Technically, the size of a singularity is zero, according to classical physics. It is just a point, and the laws of physics end at the event horizon. Our physics stop working when you get down to a certain length (Planck length). There is no way of knowing.
For further clarification: This dimension refers to the event horizon, which is merely an abstract value representing the distance from the black hole - closer than which light cannot escape.
There is no physical object that delineates this boundary.
A black hole has no center.
Just wondering: is the singularity black, when seen inside event horizon?
Does the "light cannot escape" apply only to event horizon (light from inside cannot cross the event horizon), but inside event horizon of a giant black hole we could actually see the singularity?
So a black hole has no center of mass.
It does. All you need to have a center of mass is mass.
If you are a singularity, your center of mass (a point) is "co-pointal" with you.
Images that we see are from the past. For example, we the Sun as it was 8 minutes ago. The singularity of a spherical black hole is in the future, so we don't an image of it.
All the current work on black-hole singularities makes that idea of space being rotated into a time direction seem dubious. According to work by Igor Novikov the inner singularity, after it has formed and settled down, should be traversable with a finite impulse from the tidal forces. Even though the strength of the tide goes to infinity, the total energy a body experiences from it is probably finite. A big enough black-hole's singularity might even be survivable by a human.
The center of a black hole is a singularity, your body is not a singularity. The spagetti left from your transit through the event horizon would be crushed out of existence.
As I've noted, depends on the singularity and just how its tidal forces change with radial distance.
It must be me, but this sounds like complete hogwash to me.
Anything that gets close to the singularity of a black hole is instantly torn appart beyond recognition.
That is the prevailing hypothesis, yes. qraal is pointing out that Novikov is suggesting there may be more to it than that.
What MeJennifer is saying is that in technical terms, r=0 is 'not part of the manifold' in the space-time solution for a black hole. Put more simply (and less correctly) this means that you can't, as suggested by others, talk sensibly about what happens 'at the singularity' since nothing can be at the singularity, since it has zero volume.
The really important point is, again as other have stated, that this is the property of the black hole solution in GR and this theory is almost certainly inadequate, and a better theory would not go singular. It is really important to stress that a singularity is not a physics thing it is just a mathematical property of a particular solution to general relativity, which probably suggests that the theory is incomplete.
Everytime someone talks about something happeing 'at the central singularity of a black hole' a logic fairy dies :cry: It's equivalent to asking what happens to your bedroom if you divide it by zero...
Inside the event horizon, space doesn't get rotated into a time direction, it's just that human-chosen labels (coordinates) have names (chosen by humans, not by nature) that are very misleading. See
https://www.physicsforums.com/showthread.php?p=1146536&highlight=bridge#post1146536.
Nope.
graal is not referring to the "central" crushing singularity, graal is referring to the weak singularity at the inner (Cauchy) horizon of roating and electrically charged black holes. Seminal work on this was done by Poisson and Israel, and this work was continued by Ori. See
http://physics.technion.ac.il/~school/Amos_Ori.pdf ,
particularly pages 15, starting at "Consequence to the curvature singularity at the IH: (IH = Inner Horizon), 16, and 24.
For Novikov's take on this, see
http://arxiv.org/abs/gr-qc/0304052.
Roughly, if components of g (the metric) are continuous but "pointy" (like the absolute value function), then first derivatives of g have step diiscontinuities (like the Heaviside step function), and second derivatives of g (used in the curvature tensor) are like Dirac delta functions. If a curvature singularity blows up like a Dirac delta function, then integration produces only a finite contribution to the tidal deformation of an object, which, if the object is robust enough, it can withstand.
''if u were at the center of a black hole which way would the gravity pull u. if it pulled u at all.
what do u guys think.''
Inside a black hole, there is a circular structure. This structure is the collapessed core of a star. So, gravity will most likely pull toward the core, then it would circulate around the core and then back out of the singularty.
Wow. That never occurred to me. Thanks for the info.
  • · Replies 22 ·
  • · Replies 17 ·
  • · Replies 27 ·
