What Happens to Gravity and Temperature at the Center of a Black Hole?
The discussion revolves around the nature of gravity and temperature at the center of a black hole, exploring theoretical implications, the concept of singularities, and the behavior of matter and energy in extreme gravitational fields. Participants also touch upon the concept of absolute zero and its measurement.
  • Some participants propose that at the center of a uniform sphere, the net gravitational force would be zero, leading to a state of weightlessness.
  • Others argue that a human could not survive the conditions near a black hole's center due to tidal forces, which would rip them apart before reaching the singularity.
  • There is a suggestion that the laws of physics break down at the singularity, making it difficult to ascertain what happens there.
  • Some participants question the existence of a center in a black hole, with claims that a black hole has no center of mass.
  • Others clarify that a singularity, while having zero size, does have a center of mass.
  • There is a debate about whether a photon can exist at the singularity and how time behaves in that region.
  • Some participants express skepticism about the idea that a singularity could be traversable under certain conditions.
  • There are discussions about the implications of gravitational time dilation and the nature of light and images related to black holes.
Participants express multiple competing views regarding the nature of gravity and temperature at the center of a black hole, the existence of a center, and the survivability of matter near a singularity. The discussion remains unresolved with no consensus reached.
Participants highlight limitations in understanding the behavior of matter and energy at singularities, the dependence on definitions of mass and size, and the unresolved nature of gravitational effects at extreme conditions.
  • #31
George Jones said:
graal is not referring to the "central" crushing singularity, graal is referring to the weak singularity at the inner (Cauchy) horizon of roating and electrically charged black holes. Seminal work on this was done by Poisson and Israel, and this work was continued by Ori. See
http://physics.technion.ac.il/~school/Amos_Ori.pdf ,
particularly pages 15, starting at "Consequence to the curvature singularity at the IH: (IH = Inner Horizon), 16, and 24.
For Novikov's take on this, see
http://arxiv.org/abs/gr-qc/0304052.
Roughly, if components of g (the metric) are continuous but "pointy" (like the absolute value function), then first derivatives of g have step diiscontinuities (like the Heaviside step function), and second derivatives of g (used in the curvature tensor) are like Dirac delta functions. If a curvature singularity blows up like a Dirac delta function, then integration produces only a finite contribution to the tidal deformation of an object, which, if the object is robust enough, it can withstand.
Thanks George. That's what I meant. Though he has interesting things to say about non-spinning BHs too.
Astronomy news on Phys.org
  • #32
Wallace is correct. Game over when you reach the event horizon of a black hole.
  • #33
Wallace said:
The really important point is, again as other have stated, that this is the property of the black hole solution in GR and this theory is almost certainly inadequate, and a better theory would not go singular. It is really important to stress that a singularity is not a physics thing it is just a mathematical property of a particular solution to general relativity, which probably suggests that the theory is incomplete.
Well, to rock the boat just a little bit, is that definably true?
For instance many solutions that have a singularity have an asymptotic flatness assumption. If a spacetime is almost flat far away from the possible black hole or even negligibly curved then the singularity may never form. And then there is the assumption of a point mass. To my thinking general relativity might imply a non-local notion of energy-momentum, so yes if we force the thing to be a point then perhaps we should not be surprised we get a singularity.
  • #34
We don't 'force' the centre of a black hole to be a point, physics does. Once the Schwarzschild radius of a body is greater than the radius of that body then all null future null paths of all points within the body end up at r=0, hence collapse to a 'singularity' is inevitable, given GR. We can also, noting other known physics, work out the stages of collapse of a dense object before it gets to this run-away collapse. For instance at certain critical densities various forces are overcome, turning the star into different states (e.g. white dwarf -> Neutron star -> Quark star...). Given the physics we know, stars of certain masses will inevitably collapse to blacks holes, so we don't need to construct the BH solution from scratch, we can actually see that real objects will evolve to that state given reasonable initial conditions.
The only way out is unknown physics, which is possible given the present problems with the theories.
Asymptotic flatness is merely a requirement enforced if you are looking at a vacuum solution. There is no reason that in a non-vaccum solution BH's can't form (i.e. a collapsing sphere in an FRW background) it just makes the maths a little more complicated, so textbook derivations often simplify things to a vacuum solution. The process of singularity formation has nothing to do with the conditions at infinity though, as you would expect since GR is a purely local theory.
  • · Replies 22 ·
  • · Replies 17 ·
  • · Replies 27 ·
