What happens to the lost energy in these situations?
  • Thread starter Thread starter Kaxa2000
    Energy Lost
The discussion centers on the transformation of energy in various scenarios involving kinetic energy (KE) and potential energy (PE). Friction converts KE into thermal energy, which is dissipated as heat, while braking in a car also generates heat through friction. When an object falls, some of its PE is converted into KE, but a portion is lost as heat due to air resistance. The overarching principle is that energy is conserved, though it often changes forms, leading to inefficiencies in energy transfer.
  • Understanding of kinetic energy (KE) and potential energy (PE)
  • Basic principles of thermodynamics, particularly energy transformation
  • Knowledge of friction and its effects on energy dissipation
  • Familiarity with heat generation in mechanical systems
  • Research the laws of thermodynamics and energy conservation
  • Explore the concept of energy dissipation in mechanical systems
  • Learn about the effects of friction on energy transfer in vehicles
  • Investigate the relationship between potential energy and kinetic energy in falling objects
Students of physics, engineers, and anyone interested in understanding energy transformations in mechanical systems and the principles of thermodynamics.
Kaxa2000
What happens to the "lost" energy in these situations?
(a) A box sliding across the floor stops due to friction. How did friction take away that KE and what happened to that energy?
(b) A car stops when you apply the brakes. What happened to its kinetic energy?
(c) air resistance uses up some of the gravitational potential energy of a falling object. What type of energy did the lost PE become?
(d) When a returning space shuttle touches down on the runway, it has lost almost all its KE and gravitational PE. Where did all that energy go?
(a) I know the energy goes into the Earth but I'm not sure how friction takes away the KE
(b) The KE goes into the Earth ?
(c) does some of the PE get transferred as KE to the surrounding air?
(d) The earth?
correct me if I'm wrong
Well, in many of your examples the energy is translated into heat(thermal energy).
The energy doesn't "go" anywhere or into anything. It is energy, not matter.
Let us talk about the car question though.(b)
When you apply the breaks, friction is created. This friction generates heat.
Now, what if you stopped your car by driving up a hill until the car stopped?
The energy would have changed from kinetic energy to potential energy.
The basic lesson is that energy can be changed from one state to another.
The secondary lesson is that this process is always inefficient, and you will always have less energy when it is over.
Hope that helps!
(d) The earth?
In all of these situations, if you were to take very careful temperature measurements of
(a) the box and the ground,
(b) the brake rotor and brake pads,
(c) the air through which the object fell and the object,
(d) the space shuttle and the air along its path,
you would find a rise in temperature. In each case kinetic energy has been turned into the type of molecular motion that gives rise to what we call heat.
This is just plain wrong. Energy is conserved. In many situations, in order to see that, you have to consider all possible forms into which it might have been changed. That is the point of doing this type of problem.
Yea that does help...thanks...but what about question c? Was I right about that? When an object falls some of the PE gets translated into KE which slows the object down right?
Nope. The translation of PE into KE speeds the object up to maintain the conservation of energy. Some of the PE is lost to heat, so the correct equation is
PE goes to KE + energy dissipated as heat
Oh okay thanks
Absolutely correct...I don't really know what I was trying to say there...
If you account for all energy, it should be a perfectly balanced equation
  • · Replies 20 ·
18K
  • · Replies 17 ·
  • · Replies 25 ·
