What is a Gradient and How is it Calculated in Image Processing?
  • Context: Undergrad
  • Thread starter Thread starter Jake
    Gradient
5 replies · 9K views
Jake
I was wondering if anyone could help me with this rather arbitrary math problem.
I need a description of what a gradient is in mostly non-math terms. I know a gradient is a sort of slope, but I don't understand where you would draw the line of what is and what is not a gradient. Meaning which slopes are and are not a gradient. Is this even calculable? I know http://en.wikipedia.org/wiki/Gradient" on it has some equations but I don't understand any of that.
I am using this for an image processing project where the maximum pixel intensity value is 765 and minimum is 0. So for example is a sequence of pixels with the values 10,15,20,25 a gradient? I'd think so, but is 9,16,21,24 also a gradient? Where do you draw the line between gradient and non-gradient?
Thanks a lot :)
Mathematics news on Phys.org
A gradient, in the mathematical sense, is a measure of how much a surface is changing. If you could imagine a small stretch of wavy ocean, you could plug in the x and y of any point on that section of ocean and you'd "get out" an arrow (a vector). That arrow will point in the steepest direction -- for example, for a climber standing at the foot of Everest, the gradient of the land at the climbers position is a vector that points UP at Everest. because from where he's standing, that's the steepest way he could go. It's hard to describe, but it's a vector Calculus topic. Loosely, though, a gradient is how something is changing from one place to another, over space. That means a lot of things can have gradients -- height, color, temperature, anything that can change from place to place.
In your sense, a gradient is used in the color sense -- one color fading to another. It's arbitrary, and I don't see any reason why you should need to "define" a gradient. Indeed, if I interpret your numbers right, both of your examples are gradients, because the color changes over space. The former gradient might look smoother though.
Perhaps try
http://amath.colorado.edu/outreach/demos/hshi/2001Spr/snake/snake.html
"Visualizing calculus: The use of the gradient in image processing"
A gradient is not a sequence of numbers, or a path. It is a vector at a single point, that describes the how the scalar function slopes there - in which direction it slopes, and how steeply it slopes. That's what a vector describes - a direction and a magnitude. This is of course multivariable calculus, and it will be of no use to you if you avoid the math. What is your background in calculus?
Ok, that clears it up. It didn't make sense that gradients could not be arbitrarily defined, although it would make things a bit simpler :|
Thanks a lot :-)
Rach3 said:
Perhaps try
None at all. However I don't think I need it. I am simply using gradients as one method of defining an edge within an image. The problem was figuring out where to draw the line of a single gradient and an edge. Since a gradient can be completely arbitrary, it looks like that can't be the only clue in finding edges.
Thanks though, the link is helpful
Well no. A mathematical gradient is different than the very specific type of gradient that you're talking about. In an image, a gradient is linear, so you could determine the beginning and end of it. It's an adopted use of the word "gradient." But since you were asking on a Math forum (and not a Photoshop forum), I assumed you wanted a definition of a gradient in general, and every image has a mathematical gradient.
One warning: watch out for round-off errors. That could be a big pain.
