What is a method to find the fundamental frequency of a pipe
The fundamental frequency of a closed pipe, such as a measuring cylinder, can be experimentally determined using resonance tube experiments and overblowing techniques. The discussion highlights that while Helmholtz frequency is typically associated with bottles that have a neck, it is not a strict requirement for closed pipes. Participants suggest using a tuning fork to create resonance by matching the air column length with the frequency, and they also mention using tools like Audacity for sound analysis. Overblowing techniques can generate audible frequencies, demonstrating the fundamental frequency without solely relying on mathematical calculations.
  • Understanding of fundamental frequency and resonance concepts
  • Familiarity with tuning forks and their application in sound experiments
  • Knowledge of sound wave behavior in closed pipes
  • Experience with audio analysis software, specifically Audacity
  • Research the principles of resonance tube experiments for sound frequency determination
  • Learn about overblowing techniques and their application in sound production
  • Explore the use of Audacity for analyzing sound frequencies and waveforms
  • Investigate the mathematical relationships governing sound waves in closed pipes
Students in physics, sound engineers, and anyone interested in experimental acoustics and sound frequency analysis.
Zoro
How can i find the fundamental frequency of a closed piep (measuring cylinder) experimentally/ physicaly. I have done the maths and found the frequency but i want another way to prove this other than simply playing the calculated frequency back at the measuring cylinder. I have heard of a method called overblowing or Helmholtz frequency and using a program named Audacity to find it but after further research, i think Helmholzt frequency can only be used on bottles where there is a "neck" or part with a smaller diameter at the top. Can i use Helholzt frquency/ overblowing?
I have already mathematically found the fundamental frequency
we used to do an experiment called resonance tube and finding the wavelength of sound waves by resonating the air column in atube -the tube length could be varied by a water head and level of water in the tube.
a tuning fork of known frequency would be brought vibrating above the air column and if the length matched the stationary wave formation a resonating sound will be heared the first resonance would be at lambda/4 and then its multiples.
i think a variation of this experiment can determine the frequency of a tube closed at one end.
Neck not required. For instance a spent .22 caliber shell casing makes an annoyingly piercing whistle when overblown; it does take a fair amount of lung power to accomplish though. It is even possible to excite an empty beer err soda bottle at double frequency, though again you do have to work at it.
17K
