What is an arcsec and how do I convert it into AU or m?
  • Context: Stargazing
  • Thread starter Thread starter marc873a
The discussion revolves around the concept of arcseconds as a unit of angular measurement and the conversion of this unit into distance measurements such as astronomical units (AU) or meters (m). The context includes calculations related to the semi-major axis of stars orbiting Sagittarius A*.
  • Some participants explain that an arcsecond is an angular measurement equal to 1/60 of an arcminute and 1/3600 of a degree.
  • There is a need to know the distance from the observer to the object in order to convert arcseconds into distance units like AU or m.
  • Some participants suggest using trigonometry or the small-angle approximation to relate angular measurements to physical distances.
  • It is noted that converting arcseconds to a physical distance requires not only the distance to the object but also the angle of the orbital plane relative to the observer's line of sight.
  • One participant mentions that the semi-major axis value provided may be an inferred orbital element rather than an observable measurement, indicating sensitivity to the distance uncertainty to the black hole.
  • Another participant proposes a formula using the small-angle approximation to calculate the semi-major axis in AU based on the angular size and distance.
  • There is a suggestion to use eccentricity to derive the semi-major axis from a provided column in the referenced table.
Participants express varying views on the necessity of additional parameters for conversion, with some emphasizing the importance of the angle of the orbital plane while others suggest that the provided values may suffice. The discussion remains unresolved regarding the exact method for conversion.
Limitations include the dependence on the distance to the black hole and the angle of the orbital plane, which are not explicitly defined in the discussion. There is also uncertainty regarding the interpretation of the semi-major axis values provided in the referenced table.
marc873a
I'm trying to calculate a few different things about sgr a* using the stars that orbit it. I have found this table which includes all the stars that orbit:
https://en.wikipedia.org/wiki/Sagittarius_A*_cluster
My problem is, that the semi-major axis is measured in arcsec, and I need it in AU or m. What is arcsec and how do I convert it into the other units?
Thanks in advance :)
Astronomy news on Phys.org
An arcsec is a measure of an angle equal to 1/60 of an arcminute, which in turn is 1/60 of a degree.
Okay, thanks. How do I convert that into a distance unit like AU or m?
You need to know how far you are from the separated objects, in AU or m.
Then you can use trigonometry, or the approximation of the sin(small angle) in radians.
They have different physical dimension, so generally you don’t.
If you want to convert to an actual semimajor axis you need not only the distance, but also the angle the orbital plane makes with the direction from the Earth.
Okay so the distance from earth to sgr a* is 26670 ly or about 2.523 * 10^20 m away. According to the wiki site I linked, the star, S2, has a semi-major axis of 0.1251 arcsec.
What would the distance from S2 to sgr a* be?
Not in this case, from the look of it. The value provided for a appears to be the actual inferred orbital element, and not an observable.
I suspect it's given in arcseconds only because the scale of the orbits is sensitive to the uncertainty in the distance to the central black hole.
What you can do is take the angular size for a from the table, treat it as if it were perpendicular to your line of sight, and use the small-angle approximation (look at the 'geometric' section): ##a=\theta d##, where a is the size of the semi-major axis in AUs, d is the distance to the black hole in AUs, and ##\theta## is the value for a in radians. You need to convert arcseconds to radians (multiply by ##\frac{\pi}{648000}##).
Or, you can just go to the column labelled q, and use eccentricity to get the semi-major axis: ##q=a(1-e)##
This column already assumes some particular value(s) for the distance to the black hole.
Thank you very much :)
  • · Replies 48 ·
  • · Replies 34 ·
14K
