What is 'cluster point' in french?
  • Thread starter Thread starter quasar987
    Point
The term "cluster point" in French mathematical literature is translated as "valeur d'adhérence." This concept is related to adherent points, which are defined such that every epsilon-ball around the point contains at least one point from the set. The discussion highlights that while every cluster point is adherent, not every adherent point qualifies as a cluster point. Additionally, "point d'accumulation" is mentioned as a related term, but it faces similar definitional challenges. The conversation emphasizes the nuances in definitions within the context of metric spaces and sequences.
quasar987
I'm not talking about how you would personally translate it.. I'm asking what is 'cluster point' in the french mathematical literature (textbooks).
Mathematics news on Phys.org
I believe it's "aaleur d'adhérence". All I did is wikipedia "Cluster Point" and then I clicked "français" on the left.
In english, an adherent point for a set E is a point x for which "for each epsilon>0, the epsilon-ball centered on x contains at least one point of E". This implies in particular that every point of E is adherent. So even if we consider the image of a sequence, {x1,x2,...}, every cluster point is adherent but not every adherent point is a cluster point.
So if cluster point = valeur d'adhérence, I wonder what "adhenrent point" is in french!
Point d'accumulation
'Point d'accumulation' runs into the same "problem" as 'valeur d'adhérence' because as defined for a set, an accumulation point of a subset A of a metric space M is a point a of M for which for all e>0, (B_{\epsilon}(a)\backslash \{a\})\cap A\neq \emptyset (i.e. every open ball centered on a contains points of A other than a).
So even if we apply this concept to the image of the sequence, every accumulation point is a cluster point but not every cluster point is an accumulation point. For instance consider the constant sequence 1,1,1,... 1 is a cluster point but the set of all accumulation points of the image, {1}, is void.
Have you considered peeking at a math french/english dictionary at some library?
This thing exists?!
How do you define "cluster point"?
If {x_n} is a sequence in a metric space M, then a clsuter point of {x_n} is a point a of M such that there is a subsequence of {x_n} converging to a.
Soit E un espace topologique. A une partie non vide de E, et aE. On dit que le point a est un point d'accumulation de A s'il est adhérent à A sans être isolé dans A. Autrement dit, a est un point d'adhérence de A-{a}.
Exemple : A=[0,1[, 1 est un point d'accumulation.
Si E est un espace métrique (en particulier un espace vectoriel normé), on montre facilement que les points suivants sont équivalents :
a est point d'accumulation de A
il existe une suite injective de points de A convergeant vers a.
tout voisinage de a contient une infinité de points de A.
Ceci montre en particulier que l'ensemble des points d'accumulation de A est un fermé.
Taken from DicoMath (french website)
I don't see how this helps but nice site, thx.
