Calculate Fnet to Find Change in Momentum
To calculate the net force (Fnet) for a change in momentum problem, first determine the change in velocity by subtracting the initial velocity vector from the final velocity vector. Use the impulse-momentum theorem, which states that the average force is equal to the mass multiplied by the change in velocity divided by the change in time. The formula for average force is F = mass * (change in velocity) / (change in time). Understanding momentum as a vector is crucial, as direction impacts the calculations. The discussion concludes with a successful resolution of the problem and acknowledgment of the assistance received.
physco827
[SOLVED] What is Fnet?
I am given a problem with an initial velocity then a final velocity, the weight and how long it took to change that velocity. They want us to get the change in momentum, but I don't know how to compute the Fnet to use in the equation. Any suggestions on the steps I should take?
To find the change in momentum, just calculate the final momentum and the initial momentum and find the difference. (Remember that momentum is a vector, so direction counts.)
What's the definition of momentum?
Thank you Doc Al for replying.
Momentum is p = (gamma)(mass)(velocity)
Having said that I still don't understand how to compute Fnet given two vectors, a mass, and a time.
I would just like to know how to compute the net force, Fnet, given the circumstances.
Is this a question about relativistic dynamics? Or ordinary non-relativistic physics?
Are you familiar with the impulse-momentum theorem? http://hyperphysics.phy-astr.gsu.edu/Hbase/impulse.html"
Actually I was not.
That link for impulse might help me out.
The force average is the mass(change in velocity)/(change in time).
The question is as follows:(took out number, substitiued x so you can't solve it for me so i can try to figure it out)
You were driving a car with velocity <x, x, x> m/s. You quickly turned and braked, and your velocity became <x, 0, x> m/s. The mass of the car was x kg. The maneuver took x seconds. What was the average net (vector) force acting on the car?
So to get that do i just use the force average formula?
Yes, that will work. Take care to find the change in velocity correctly (subtract them as vectors).
Thank you very much Doc.
I solved the equation thanks to your help and now know what Fnet is. You are awesome.
  • · Replies 19 ·
