What is inertia? What is its source?
  • Thread starter Thread starter SinghRP
    Inertia Source
Inertia is defined as the resistance of an object to changes in its state of motion, often linked to mass. The term is ambiguous and can refer to various concepts like mass, momentum, or energy required for acceleration. Historical figures like Galileo, Newton, and Einstein have contributed to the understanding of inertia, with Einstein proposing that inertial mass and gravitational mass are equivalent. Mach's hypothesis suggests that inertia may arise from the mass of the universe, though this remains unproven. The discussion emphasizes the need for clarity in defining inertia and its implications in physics.
SinghRP
What is inertia? What is its source? Is inertial mass mass? Do gravitational mass and inertial mass have the same sign?
Inertia is a term physicists don't use by itself all that often. The meaning of "inertia" is a bit ambiguous: Does it mean mass, linear momentum, angular momentum, mass*distance squared, or something else? Without context, it is a bit difficult to tell. What do you mean by "inertia"?
Physicists eschew the word for a simple reason: Why use an ambiguous term when there are perfectly good and much less ambiguous alternatives?
Well, I started this inertia topic. This one is not clear even today. I am working on it as a research topic.
Galileo, Eotovos, Newton, Mach, Enistein, Dicke addressed it. Inertia is resistance to acceleration. Mach thought, but could not prove it, that inertia is due to the rest of the mass in the universe. Einstein's principle of equivalence: inertial mass and gravitational mass are the measures of the same quantity. General Relativity has not yet accommodated it.
Well, maybe some one can shed some light.
Inertia: the resistance an object has to a change in its state of motion.
Are you familiar with what heat capacity is? Its the amount of energy it takes to raise the temperature of something by 1 degree.
Inertia would be quantitatively analysed as the amount of energy it takes to raise the speed of a mass by 1m/s . Something quite heavy would have a large value for inertia, just like water has a large value for heat capacity.
Also note that this works the other way around. It would take the same energy to slow it down as it would to speed up, and the same energy to heat up as it would to cool down.
Hamden and DH,
I agree with you. Inertia is not only with mechanical motion. One example is the one, DH, you cited.
In the mechanical world, I like to use momentum (including angular moentum) instead of motion, even though motion is by all means okay. Reason: orbital, vibrational and spin motions may not be included in motion when describing inertia. (At very low tepperatures you will need more heat to raise the temperature by 1 degree.)
Einstein: gravitational mass is numerically equal to inertial mass. Scenario: a body falling to the earth. As the gravitational mass is more, gravitational force increases; but then inertial mass is equally more, which increases the inertia or resistance. That's why two bodies with different masses fall with the same acceleration.
Let's continue this discussion. What's the source of inertia? Mach thought it was due to the rest of the universe. [The body does not resist, but the universe does?] What do you think?
For simple comparison, I think the same thought process can be followed as a block slides down a hill, - for block down hill, simple starting PE of mgh to final max KE 0.5mv^2 - comparing PE1 to max KE2 would result in finding the work friction did through the process. efficiency is just 100*KE2/PE1. If a mousetrap car travels along a flat surface, a starting PE of 0.5 k th^2 can be measured and maximum velocity of the car can also be measured. If energy efficiency is defined by...
  • · Replies 22 ·
