What is instantaneous acceleration?
Instantaneous acceleration is defined as the rate of change of velocity at a specific moment in time, mathematically expressed as a(t_{0})=\lim_{\Delta t \rightarrow 0}\frac{v(t_{0}+\Delta t)-v(t_{0})}{\Delta t}. This concept is crucial in physics, particularly in calculus, where both instantaneous velocity and acceleration are treated as derivatives with respect to time. The discussion highlights the logical challenges some users face in accepting instantaneous acceleration as a valid concept, emphasizing the need for a solid understanding of calculus to grasp these definitions fully.
  • Understanding of calculus, specifically derivatives
  • Familiarity with the concepts of velocity and acceleration
  • Knowledge of limits and their application in calculus
  • Basic physics principles related to motion
  • Study the concept of derivatives in calculus, focusing on dv/dt and dx/dt
  • Explore the relationship between instantaneous velocity and instantaneous acceleration
  • Review examples of instantaneous acceleration in real-world scenarios, such as vehicle motion
  • Investigate the mathematical definitions of limits and their significance in physics
Students of physics, educators teaching calculus and motion concepts, and anyone interested in understanding the mathematical foundations of acceleration and velocity.
  • #31
A.T. said:
Right, so if you understand instantaneous velocity, then what is your problem with Instantaneous acceleration? Both are derivatives w.r.t time.We cannot help you, if you just keep repeating "How can it be..." without explaining what your problem with it is.
I just edited my post
  • #32
parshyaa said:
Suppose i am applying force continuously on an object, then object accelerates, and then somebudy asked what is the acceleration of that object when time was 4 second
a = F / m
  • #33
A.T. said:
a = F / m
Yes but i just gave that example to explain the importance of instantaneous acceleration, finally acceleration is the ratio of velocity w.r.t time , therefore it can occur at a particular instant of time.
  • #34
Then you should add that the force or mass varies with time. Otherwise instantaneous acceleration equals average acceleration.
  • #35
Yes, i meant the same.
  • #36
Acceleration is the derivative of velocity wrt time.
It sounds like you now agree that instantaneous acceleration is meaningful, just like instantaneous velocity.
  • #37
parshyaa said:
Instantaneous velocity: its the velocity of an object at a particular instant/moment of time.
mathematically: Its the rate of change of displacement/position of an object w.r.t time.
Instantaneous acceleration: its the acceleration of an object at a particular instant/moment of time.
Mathematically: its the rate of change of velocity w.r.t time.
Suppose i am applying force continuously on an object, then object accelerates, and then somebudy asked what is the acceleration of that object when time was 4 second, therefore introduction of instantaneous acceleration is must.
Thank you
@Dale
  • #38
parshyaa said:
You didn't ask any questions, but all of those statements look fine.
  • #39
Yes,because my doubt is clear now, thanks to all of you
  • #40
  • #41
rumborak said:
On a related side note, there is something called "jerk" in physics, which is the derivative of the acceleration over time:
https://en.m.wikipedia.org/wiki/Jerk_(physics)
And the jerk is what actually happens in pretty well every mechanical occurrence . Put your foot down on a car accelerator and you will find the force on your back varies with time. (Like when the turbo kicks in. You can't use the SUVAT equations with motor cars because the acceleration is not uniform at all.
Edit: When I first was taught SUVAT in School, I missed the word "uniform" in "uniform acceleration'. That looking out of the window incident accounted for a lot of initial problems with comprehension. I wish I had learned that lesson because I have been nodding off regularly at vital moments ever since. :rolleyes:
  • #42
like a lot of people out there that paradoxical thing bugged me since high school, but no one ever seemed to explain me better than this guy:
OP I strongly advise you to watch this video to really get a clear(er) picture of a derivative.
  • #43
The video posted by LLT71 is interesting, " Instantaneous rate of change" is explained clearly in that. Simply it is the rate of change occurs during a very small duration of time, when we take the derivative we allow the time difference to approach zero,
  • #44
He deals with the apparent problem quite well but he doesn't really needs go to all that trouble. If you are prepared to use Maths as the primary way of explaining this sort of process and only use hand waving as a secondary medium, there never would be a problem. This is all down to Mathsphobia, imo.
  • · Replies 22 ·
  • · Replies 17 ·
