What is monotonic transformation? (economics)
Monotonic transformation refers to the process of transforming a set of numbers while preserving their order. In the discussion, examples such as u = 2v - 13 and u = ln(v) are confirmed as monotonic transformations, while u = -1/v2 and u = v2 are not. The conversation also explores the concept of monotonicity in functions of multiple variables, specifically how to analyze functions like u = x²y² using partial derivatives to determine monotonic behavior in different quadrants.
  • Understanding of monotonic functions in mathematics
  • Familiarity with single-variable calculus
  • Knowledge of partial derivatives
  • Basic graphing skills for functions
  • Study the properties of monotonic functions in detail
  • Learn about partial derivatives and their applications in multivariable calculus
  • Explore graphical representations of functions in multiple dimensions
  • Investigate the implications of monotonic transformations in economic models
Students of economics, mathematicians, and anyone studying calculus or multivariable functions who seeks to understand the concept of monotonic transformations and their applications.
60051
The textbook says it's a way of transforming a set of numbers into another set that preserves the order. But I don't understand what that means.
Here are a few examples. The question was: do these functions represent a monotonic transformation.
u = 2v - 13 (yes)
u = -1/v2 (no)
u = ln(v) (yes)
u = v2 (no)
I have no clue what you're supposed to look for.
Hi 60051! :smile:
It means the graph is always going up (or always going down).
Look at the graph for the second and fourth examples …
if we include negative values of v, then the graph of u against v (u up and v across) comes down and then goes up …
for example, in the fourth one, -2 < 1 < 60051, but (-2)2 > 12 < 600512, so the order isn't preserved. :wink:
What if there are two variables?
You mean if, say, you are told that "u is a monotonic function of x and y"?
I've never heard of "monotonic" being used for two (input) variables, but I suppose it would mean that, for each fixed value of y, u is a monotonic function of x, and for each fixed value of x, u is a monotonic function of y (and I expect they'd need to be either both monotonic increasing or both monotonic decreasing).
But that seems completely different from your textbook, which says that it's a way of transforming a set of numbers into another set that preserves the order …
that presumes that the original set of numbers has an order, and a two-variable set of numbers doesn't have any obvious order (eg is (3,7) before or after (5,5) ?). :wink:
All four examples you gave have two variables -- u and v. In each of those examples u is a function of v.
tiny-tim already answered for a situation in which there are three variables, where, for example, z is a function of two variables, x and y.
Say you have an example like:
u = x2y2
So du/dx = 2xy2, and du/dy = 2yx2.
So how do you tell if the graph is always rising or falling?
u = x2y2
As tiny-time said, "monotonic" is normally used for functions of several variables.
Here, it is clear that x^2 and y^2 are always non-negative so whether the du/dx is positive nor negative depends on the sign of y and whether du/dy is positive or negative depends on the sign of x.
In the first quadrant, where x> 0 and y> 0, du/dx and du/dy are both positive so the function increases as both x and y increase. In the third quadrant where both are negative, the function decreases as both x and y increase. In the second and fourth quadrants, whether the function vaue increases or decreases with increasing x and y depends on the precise values of x and y.
Put y constant, and see whether du/dx is always positive (or always negative).
Put x constant, and see whether du/dy is always positive (or always negative).
EDIT: ooh, HallsofIvy beat me to it! :smile:
(but i think he meant ' "monotonic" is normally used for functions of one variable ')​
The graph is not a single curve; it's a surface in three dimensions.
Your textbook seems to be talking about functions of a single variable. As tiny-tim pointed out, there is no obvious way of determining whether one ordered pair is "less than" another ordered pair.
BTW, if u = x2y2, the partial derivatives have meaning, but not the ordinary derivatives.
IOW
\frac{\partial u}{\partial x} = 2xy^2
and
\frac{\partial u}{\partial y} = 2x^2y
I'm sure you meant functions of a single variable.
  • · Replies 0 ·
  • · Replies 17 ·
