What is the area of a segment bounded by a chord and an arc in a circle?
  • Context: MHB
  • Thread starter Thread starter Heathcoat
    Area Circle
The discussion revolves around calculating the area of a segment in a circle defined by a chord and an arc. Participants are exploring the geometry involved, including the use of trigonometric relationships and the law of cosines, while addressing specific values for the chord length and angle.
  • Homework-related
  • One participant presents the problem of finding the area of a segment bounded by a chord and an arc, providing specific measurements for the chord and angle.
  • Another participant suggests using the law of cosines to find the radius and then calculating the area of the sector and triangle to determine the segment area.
  • A different participant mentions obtaining a radius of \(6\sqrt{6}\) and proposes that the segment area is one-third of the circle's area, but expresses difficulty in calculating the triangle's area.
  • There is a discussion about using trigonometric functions to find the height of the triangle, with one participant indicating that they are not familiar with these concepts.
  • One participant attempts to clarify the geometry by describing the right triangle formed by the altitude from the circle's center to the chord, but another participant expresses confusion regarding the triangle's properties.
  • Participants discuss the relationship between the triangles involved, with one noting that the area of one triangle is half that of another, but this leads to further confusion for some participants.
Participants do not reach a consensus on the approach to solving the problem, with various methods and interpretations of the geometry being proposed. Confusion persists regarding the relationships between the triangles involved and the appropriate calculations needed.
Some participants express uncertainty about the use of trigonometric functions and the geometry of the triangles, indicating a potential gap in foundational knowledge that affects their understanding of the problem.
Heathcoat
This one is kicking my butt. In a circle, find the exact area of a segment bounded by chord $$\overline{CD}$$ and $$\stackrel{\frown}{CD}$$. $$\overline{CD}=12\sqrt{3}$$ and the $$\measuredangle \stackrel{\frown}{CD}=120^{\circ}$$.
Mathematics news on Phys.org
Hi, and welcome to the forum.
Using the law of cosines, find the radius $r$. Then find the area of the $120^\circ$ sector. Finally, find the area of the triangle: $\frac12r^2\sin120^\circ$ and subtract it from the area of the sector.
Heathcoat said:
Not sure why the symbols didn't work
You should enclose LaTeX code in dollar signs or $$...$$ tags (the $\Sigma$ button in the toolbar above the text box where you type your post).
Hello and welcome to MHB, Heathcoat! :D
I have enclosed your $\LaTeX$ codes in MATH tags, and added a few symbols.
Here is a sketch of the problem:
Can you use the above suggestions to find the green area?
I am getting the radius as 6rad6. using this I can find the area of the circle, and the segment is 1/3rd the area of the circle. I then need to subtract the area of the triangle from the area of the segment. I am struggling with finding the area of the triangle. The formula I know is A=1/2bh. My base is 12rad3 but I don't remember how to find the height of the triangle to use this formula. Cosine and sin is well above what I have learned so far (basic geometry level, no calculus)
Please write \$6\sqrt{6}\$ instead of 6rad6. It produces $6\sqrt{6}$.
If you draw an altitude $OH$ from the center $O$ of the circle to $CD$, then you get a right triangle $OCH$ with angles $90^\circ$, $60^\circ$ and $30^\circ$. You know the long leg: $6\sqrt{3}$. and you probably know that the short leg, which faces $30^\circ$, is half the hypotenuse, or the radius $r$. Using the Pythagoras theorem, you should be able to find $r$. I get $r=12$. Knowing $OH=r/2$, you can find the area of $\triangle OCD$.
Honestly, I am having enough trouble figuring out the geometry without also trying to figure out how to use the proper html or coding process for this site. My brain is thoroughly taxed trying to figure out this problem without trying to tack on new things to learn. You knew what I meant by 6rad6, right? It seems to me that both legs from the triangle will be radii, so how can this be a 30,60,90? Perhaps this site isn't equipped to deal with people at lower levels of understanding of math, because your answer makes me more confused than when I started.
Which triangle are you talking about? I was describing $\triangle OCH$ where $O$ is the center of the circle and $OH$ is altitude in $\triangle OCD$. That is, $H$ lies on $CD$ and $OH$ is perpendicular to $CD$. Again, the triangle with $90^\circ$, $60^\circ$ and $30^\circ$ is $\triangle OCH$.
Ok, sorry for my confusion. The triangle I was referring to is triangle OCD, which needs to be subtracted from the segment of the circle OCD to get the answer I am looking for. Thanks for your help, I am just not getting this, it's all way over my head.
But, $\triangle OCH$ is just the bisection of $\triangle OCD$, that is the area of the smaller is half the area of the larger. :D
