What is the Area of the Shaded Region in Trigonometry Problem?
  • Context: MHB
  • Thread starter Thread starter Alaba27
The discussion revolves around a trigonometry problem involving the calculation of the area of a shaded region within a circle, specifically related to the sine function and circular sectors. Participants are exploring methods to derive the area step-by-step, addressing both geometric and trigonometric aspects of the problem.
  • Homework-related
  • One participant seeks guidance on how to find the area of the shaded region defined by the equation sin(x) = (√3)/2 in a circle.
  • Another participant suggests calculating the area of the circular sector OAB and subtracting the area of triangle OAB.
  • There is a clarification regarding the length of OA, with a participant noting it should be 1, leading to a recalculation of the length of AB.
  • Participants discuss the radius of the circle, confirming it is 1, and explore the height of triangle AOB.
  • One participant proposes a method involving the area of the entire circle and its segments, but another points out the need to focus on the area of the circular sector instead.
  • There is a discussion about the formula for the area of a circular sector and the correct interpretation of the angle involved.
  • One participant attempts to apply the sector area formula but misinterprets the angle, leading to a correction from another participant.
Participants generally do not reach a consensus on the correct approach to finding the area of the shaded region, with multiple competing methods and interpretations of the problem being presented.
There are unresolved aspects regarding the interpretation of the angle in the circular sector and the relationship between the sine function and the angle x. The discussion reflects varying levels of understanding and familiarity with the concepts involved.
Alaba27
Hi again,
I'm completing my tutoring booklet for trigonometry and I have a question that is quite difficult. I've never done anything like it and my solutions page only has the final answer. I'd like to see how the result is found step-by-step, so if anyone can help me out or at least guide me to the solution it would be much appreciated.
http://speedcap.net/sharing/files/57/af/57afa49f650622a931c668f649477a83.png
http://speedcap.net/sharing/files/6a/e5/6ae5a228d615fb949ba020cd1a1c725d.png
If you cannot read the question, it is:
sin(x) = (√3)/2 in the circle with centre O, shown on the right. Furthermore AB // OP and m OA = 1 unit. What is the area of the shaded region?
Thanks in advance!
Mathematics news on Phys.org
I would suggest finding the area of the circular sector $$OAB$$ (you know or can find the radius and the subtended angle), then subtract away the area of $$\Delta OAB$$.
I notice you have $$\overline{OA}$$ marked as 2, but it should be 1, making $$\overline{AB}=\sqrt{3}$$.
Thanks for the reply! So would OA be identical to OB, then?
Alright, I managed to answer my own question. OA and OB are identical. But how can I find the radius of the circle? I guess that is basically what the entire issue is, seeing as how I cannot get the radius from the diagram (I think).
Thanks in advance!
The radius is $$1=\overline{OA}=\overline{OB}$$. Any line segment from the center to a point on the circle is a radius.
OK, then. But the height of the triangle AOB is still 1/2, am I correct? I have gotten this:
Area of Circle
A = (pi)(r)^2
= (pi)(1)^2
= (pi) units
Area of Triangle AOB
A = (BxH)/2
= (√3 x 0.5)/2
= (√3)/4 units
So I would subtract the Area of the Triangle AOB from the Area of the Circle, and I would get the shaded area?
Thanks in advance!
You want to subtract the area of the triangle (which you have correctly computed) from the area of the circular sector, not the entire circle. Do you see why?
My apologies, I've never done a question like this before and I don't see anything from my notes or previous questions that resembles something along these lines. So I am going to guess that I have to do this:
> Divide area of entire circle by 2
> Divide segments by 2 both times (because the top right and bottom right segments are broken in half)
> Add together
So, something like this:
Area of entire circle = π units
(The circle has 4 equal segments)
Area of 1 segment = π/4
(2 segments of the same size, so multiply by 2)
Area of both full segments = 0.5π
(For segments that are cut in half, divide π/4 by 2)
Area of half-segment = 1/8π
(Multiply the half-segment by 2 because there are 2 of them)
Area of both half-segments = 0.25π
Add them together = 0.75π
Is this correct?
Using your method, you could get the correct result, but the picture is misleading you with regards to the angle. The angle is actually larger than it is drawn.
The formula for the area $A_S$ of a circular sector is given by:
$$A_S=\frac{1}{2}r^2\theta$$
Now, we already know $r=1$, and we know $$\theta=2x$$, and we know:
$$\sin(x)=\frac{\sqrt{3}}{2}$$
So, can you find $x$, then substitute for $r$ and $\theta$ in the above formula for the area of the sector?
OK, so I followed what you said and got this:
A = (0.5)(r)^2(θ)
= (0.5)(1)^2([√3]/2 x 2)
= (√3)/2 units
Is this correct?
No, you are using $$\theta=2\sin(x)$$, but what we need is $$\theta=2x$$
If $$\sin(x)=\frac{\sqrt{3}}{2}$$ and $$0<x<\frac{\pi}{2}$$ then what is $x$?
11K
26K
  • · Replies 40 ·
