What is the area of this part of a circle?
  • Thread starter Thread starter kaizokonpaku
    Area Circle
The discussion revolves around finding the area of a specific part of a circle, with references to various geometric properties and relationships. Participants explore the context of the problem, which involves segments and sectors of circles, and the challenge of calculating the area without direct reference to the circle's center.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss different methods for calculating the area, including considering the part as a segment of another circle and using trigonometric relationships. Some express confusion about initial steps and the validity of their approaches, while others suggest visualizing the problem through geometric reflections.
The discussion is active, with participants sharing their attempts and questioning each other's reasoning. Some have provided insights into alternative methods, while others are still grappling with the problem's complexities. There is no clear consensus on the correct approach, but several productive lines of reasoning have been explored.
Participants note that the problem may require trigonometry and that the provided answer does not align with their calculations, indicating potential misunderstandings or misinterpretations of the problem setup.
kaizokonpaku
the figure is shown on the attachment. Find the area of the smallest part of the circle.
area of circle, sector, segment
I cannot use the said equations since the part of the circle is not with reference to the center. I cannot think also of any formulas for this kind of problem.
Please help.
Consider that part as a part of another circle whose radius is 7. :wink:
I already did that but the resulting answer is not the same with the given answer.
Are you sure? :wink:
Can you show us your steps and calculations?
Infinitum said:
Are you sure?
Not quite, but let me check it out once more.
If that is another circle, then the area would be a quarter circle
A = (pi)(7^2) / 4 = 38.48. however, the given answer is 31.
Your first step should be to demonstrate that the corner of that square lies at the centre of the large circle.
I do not get the first step.
Lest anyone be misled into thinking this apparently is an easy problem you can solve in your head ... :frown:
You do need some trig and a calculator, and the answer is not an integer. I get 31.0126
This can be done the hard way, or a very easy way.
Hard way: use trig to find certain angles, then prove that a geometric property of a circle (angle subtended by a chord at circumference = half angle subtended at centre). I was mucking around with this for a few minutes (and actually did it) before inspiration struck and I found the easy way.
Easy way: Reflect the figure vertically and superimpose the mirror images (getting two vertically stacked 5X5 squares). Now reflect that figure laterally, and superimpose the mirror images (to get four 5X5 squares). You will find that, with the dimensions given, one vertex of each of those squares will exactly touch the others, proving that that is the centre.
Now, after you've done that, the easiest way to find the required area is to visualise it as the sum of areas of a segment and a right triangle. Determining the angle subtended by the segment requires a little trig, but nothing too difficult.
I did this. Couldn't post about it because I had to go out :frown: The answer doesn't come out to be exact, as NascentOxygen pointed out.
Interesting method, Curious(10^3)Pi! :smile:
Thanks, but I only found it because I'm always trying to find the lazy way out. :-p
I solved it and I got it using the easy way. Thanks for the help :)
  • · Replies 24 ·
25K
  • · Replies 62 ·
11K
