What Is the Ball's Angular Velocity in a Conical Pendulum?
2 replies · 19K views · last reply
charan1
A conical pendulum is formed by attaching a 0.900 kg ball to a 1.00 m-long string, then allowing the mass to move in a horizontal circle of radius 10.0 cm. The figure (Intro 1 figure) shows that the string traces out the surface of a cone, hence the name. (Figure Attached)
What is the tension in the string? Got this one right 8.86N
What is the ball's angular velocity, in rpm? (Need help with this one)
a=(w^2)(r)
Fnet=(m)(w^2)(r)
I got the first question pretty easily, but then I did this to find the second and it was wrong, I think i did something wrong in my conversion from rad/s to rpm's please check.
I got the angle like this-
cos^-1=.05m/1m=87.13 degree's
Then for the Force towards the center of the circle on the x-plane-
cos(87.13) x 8.86N=.444N
Then for the angular velocity-
F=(w^2)(m)(r)
.444N=(w^2)(.9)(.1)
w=2.22 rad/s
Then convert to rpm-
2.22rad / 2pie x 60 seconds = 21.2rpm and this is wrong where did i go wrong?
If the radius is 10 cm (0.1 m) why do you have 0.05 here?
How did you get the tension without using the angle? With similar triangles?
Thanks I got it!
used the wrong r value to get the angle once I got the angle I calculated everything and got the answer to be 30 rpm
