What is the ball's maximum height?
The maximum height of a ball thrown upward with an initial vertical speed of 10.8 m/s and an acceleration due to gravity of 9.8 m/s² can be calculated using the equation vf² = vi² + 2*a*d. At the maximum height, the final vertical speed (vf) is 0 m/s. By rearranging the equation, the height (d) can be determined as d = (vi²) / (2*a), resulting in a maximum height of approximately 7.5 meters.
  • Understanding of kinematic equations
  • Knowledge of initial and final velocity concepts
  • Familiarity with acceleration due to gravity
  • Ability to manipulate algebraic equations
  • Study kinematic equations in detail
  • Learn about projectile motion and its applications
  • Explore the effects of air resistance on projectile motion
  • Practice solving problems involving maximum height calculations
Students studying physics, educators teaching kinematics, and anyone interested in understanding projectile motion and height calculations.
Casey314stl
A ball is thrown upward.
What is its maximum height? Its initial
vertical speed is 10.8 m/s and the acceleration
of gravity is 9.8 m/s^2
Neglect air resistance.
Answer in units of m
dfinal=dintial+vfinalΔt+ 1/2averageaccelerationΔt^2 or v^2final=v^2initial +2averageaccelerationΔd
No remember that since the object is traveling up it will have a negative speed therefore:
Vf^2=u^2+2is
Vf^2=u^2+2is
what does u and is stand for?
u and v are vectors v is the final speed which in your case will be 0 because the kinetic energy will be 0 at the maximum height so you will be left with 0=speed of the ball -2(speed of gravity)s.
so how do i use this to find the height?
0=(initial speed)^2-2(speed of gravity)s then once you have this down just solve the equation.
mtayab1994 said:
0=(initial speed)^2-2(speed of gravity)s than once you have this down just solve the equation.
I am solving for Vf^2 which is vertical speed final?
so I plug in 0-2(10.8)=-21.6?
Your second equation looks promising. In more compact terms:
vf2 = vi2 + 2*a*d
where vi is the initial velocity, vf the final velocity, a is the acceleration and d is the distance. The distance d is what you're looking for. What values will you assign to the other variables?
  • · Replies 38 ·
