What is the ball's maximum height?
The problem involves a ball thrown upward, with the goal of determining its maximum height given an initial vertical speed of 10.8 m/s and an acceleration due to gravity of 9.8 m/s², while neglecting air resistance.
  • Participants discuss the use of kinematic equations to relate initial speed, final speed, acceleration, and distance. There are questions regarding the definitions of variables used in the equations, particularly concerning the signs of speeds and the meaning of terms like 'u' and 'is'.
The discussion is ongoing, with participants exploring different interpretations of the kinematic equations. Some guidance has been offered regarding the relationships between the variables, but there is no explicit consensus on the approach to finding the maximum height.
There are indications of confusion regarding the signs of the velocities and the assignment of values to variables in the equations, which may affect the calculations. The original poster has reiterated the problem statement and equations, suggesting a need for clarification on the setup.
Casey314stl
A ball is thrown upward.
What is its maximum height? Its initial
vertical speed is 10.8 m/s and the acceleration
of gravity is 9.8 m/s^2
Neglect air resistance.
Answer in units of m
dfinal=dintial+vfinalΔt+ 1/2averageaccelerationΔt^2 or v^2final=v^2initial +2averageaccelerationΔd
No remember that since the object is traveling up it will have a negative speed therefore:
Vf^2=u^2+2is
Vf^2=u^2+2is
what does u and is stand for?
u and v are vectors v is the final speed which in your case will be 0 because the kinetic energy will be 0 at the maximum height so you will be left with 0=speed of the ball -2(speed of gravity)s.
so how do i use this to find the height?
0=(initial speed)^2-2(speed of gravity)s then once you have this down just solve the equation.
mtayab1994 said:
0=(initial speed)^2-2(speed of gravity)s than once you have this down just solve the equation.
I am solving for Vf^2 which is vertical speed final?
so I plug in 0-2(10.8)=-21.6?
Your second equation looks promising. In more compact terms:
vf2 = vi2 + 2*a*d
where vi is the initial velocity, vf the final velocity, a is the acceleration and d is the distance. The distance d is what you're looking for. What values will you assign to the other variables?
  • · Replies 38 ·
