What is the charge enclosed by the cubical box?
  • Thread starter Thread starter craka
    Charge Surface
The problem involves calculating the charge enclosed by a cubical box given the total electric flux. The context is rooted in Gauss's Law and electric fields.
  • Participants discuss the application of Gauss's Law and the implications of using the surface area of a sphere versus a cube. There are questions about unit consistency and the relevance of surface area in relation to the given flux.
Some participants have offered guidance on the correct application of formulas and highlighted potential mistakes in the original calculations. Multiple interpretations of the problem are being explored, particularly regarding the use of surface area and the nature of the given answer.
There is a noted confusion regarding the units of the answer and the relevance of the surface area in the context of the problem. Participants are also reflecting on the challenges of identifying small mistakes in their calculations.
craka
Question states "Total electric flux from a cubical box 0.28m on a side is 1.84x10^3 Nm^2/C. What is the charge enclosed by the box
Gauss's Law
[tex] \begin{array}{l}<br /> \phi _E = \vec E \bullet \vec A \\ <br /> \oint {\vec E \bullet d\vec A = \frac{{Q_{enclosed} }}{{\varepsilon _0 }}} \\ [/tex]
[tex] \begin{array}{l}<br /> Q_{enclosed} = (4\pi r^2 )\varepsilon _0 \phi _E \\ <br /> \varepsilon _0 = 8.85 \times 10^{ - 12} \\ <br /> \phi _E = 1.84 \times 10^3 \\ <br /> r = 1.2 \times 0.28 = 0.14 \\ <br /> Q_{enclosed} = 4.01 \times 10^{ - 9} Nm^2 /C \\ <br /> \end{array}[/tex]
But the answer is given as 1.63*10^-8 Nm^2/C
What I have I done wrong here?
I noticed the following mistakes at first glance:
1) You have a cubical box, yet you are using the surface area of a sphere: [itex]4\pi r^2[/itex]
You need to use the surface area of this cube, which is the sum of the area of each side.
2)The correct answer you give has the wrong units. The units should be C, not Nm^2/C. Check that answer to make sure it corresponds to this problem.
Are either of these the problem?
Sorry I do realize the units should be in Coulombs I just in autopilot when I was typing units in sorry.
As far as the Areas goes, that what I thought initially aswell.
When I calculated the surface area initially I did so for a cube.
Thus 6x^2 where x was side dimension of cube. ie the 0.28m
When I calculate that my final answer for charge is 7.66*10^-9 Coulombs
This is still not the answer given, which is 1.63*10^-8 Coulombs.
Am I wrong or the answer in the text?
You are given the *flux*, the area is totally irrelevant for this question.
Thanks borgwal, that made it pretty damn easy.
Qencl= permitivity of free space * electric flux
Yep, sometimes the easiest questions are the hardest :-)
Heh! It's always the little mistakes that get you. I don't know how I missed that. Sometimes I look at these forums right before bed, and I miss things I would otherwise see. Sorry about that! :redface:
No worries. It's just great that you people put your time in a forum such as this.
Thanks
12K
12K
12K
