What is the charge of a point at the center of a ring
The discussion centers on calculating the charge of a point at the center of a uniformly charged ring with a radius of 0.71m and a total charge of +580nC. The electric field at a point 0.73m from the center of the ring is zero, requiring the point charge Q to produce an equal and opposite electric field. The participants utilized the formula E = k*(λ*.73)/(.73^2+.71^2)^(3/2)*2*pi*.71 to derive the electric field and subsequently calculated the charge Q, arriving at a value of approximately -290nC, which is incorrect as the expected answer is -210nC. The discrepancy arises from the misunderstanding of charge density versus total charge.
  • Understanding of electric fields and point charges
  • Familiarity with the formula E = k*Q/r^2
  • Knowledge of charge density and its application
  • Basic calculus for integrating charge distributions
  • Review the concept of electric fields generated by charged rings
  • Study the differences between total charge and charge density
  • Learn about the integration of charge distributions in electrostatics
  • Practice problems involving point charges and electric fields
Students studying electrostatics, physics educators, and anyone preparing for exams involving electric fields and charge distributions.
nateja
In the figure (I'll try to find it) a ring of radius .71m carries a charge +580nC uniformly distributed over it. A point charge Q is placed at the center of the ring. The electric field is equal to zero at field point P, which is on the axis of the ring, and 0.73 m from its center.The point charge Q is... then give's multiple choice solutions.
E = 1/(4*pi*epsilon_0) Q/r^2
My first attempt got me the wrong value. I tried to find the E-field and integrate the little bits of charge around the disk but my answer was too large. I know that the E field from the ring will push put an E field on P that goes out in the x-direction along the axis. So in order for the E field to be 0 at point P, the charge Q must put out an E field of equal magnitude but opposite direction.
Using the below formula, I then set the E equation = to the value I calculated and solved for Q, but then got the answer that was too large.
E = k*(λ*.73)/(.73^2+.71^2)^(3/2)*2*pi*.71 (got this equation from integrating and using λ = 580nC/m
My friend tried a different way: plugging in 580nC for the charge (where I had used it for the charge density) and (.73)^2+(.71)^2 for r^2 into. We both got an E = 5029 N/C. Then we set that value equal to the E equation:
-5029 = k*q/r^2
q = (-5029/k)*r^2 = (-5029/4*pi*8.85*10^-12)*(.73^2) = -2.97*10^-7 (-290nC)
The answer is supposed to -210nC
The charge given for the ring is the total charge, not the charge density.
