What Is the Coefficient of Static Friction for a Ladder Leaning Against a Wall?
The discussion revolves around a physics problem involving a ladder leaning against a wall, specifically focusing on determining the coefficient of static friction at the base of the ladder. The scenario includes a uniform ladder, its mass, the angle it makes with the wall, and the weight of a person standing on it.
  • Mixed
  • Participants discuss the application of torque and forces to analyze the ladder's stability. There are attempts to set up equations for torque and force balance, but some participants express confusion about the role of friction and the direction of forces involved.
Several participants are engaged in clarifying the setup of the problem and the equations used. There is a recognition of the need to accurately account for the forces acting on the ladder, particularly the frictional force and its effects on torque. Some participants are questioning the assumptions made in the original equations.
Participants note the complexity of the problem due to the interactions between the forces at play and the geometry of the ladder's position. There is also mention of the original poster's inexperience with the topic, which may influence their understanding of the problem.
kritzy
A uniform 6.0m long ladder of mass 17.0 kg leans against a smooth wall (so the force F_w exerted by the wall, , is perpendicular to the wall). The ladder makes an angle of 22.0 with the vertical wall, and the ground is rough.Determine the coefficient of static friction at the base of the ladder if the ladder is not to slip when a 75.0kg person stands three-fourths of the way up the ladder.
τ=RxF
F=ma
N=normal force from ground
I thought that if I take the sum of torques and the sum of the forces I could determine the static friction but I'm stuck.
Assuming that my axis of rotation is the point where the ladder is leaning against the wall
τ= [1.5 x (75)(9.8)(cos(22))] + [3 x (17)(9.8)(cos(22))] + [Nsin(22)]=0
Y-direction: sum of forces
F=N-(75)(9.8)-(17)(9.8)=0
X-direction: sum of forces
F=µN=0
I'm stuck because the coefficient of static friction can't be zero. Can somebody please help?
τ=RxF
F=ma
F=µN=0
According to your equation, the torque resulting from the frictional force is acting to rotate the ladder in the same direction as the weight of the person and the ladder.
Furthermore, in your equation it appears that the frictional force is acting 1m from the pivot, which is not the case.
So, the torque from friction shouldn't be rotating in the same direction as the person?
Which equation do I need to change, the torque?
In which direction does the frictional force act, towards or away from the wall?
Actually I am new to this forum and also reading physics after almost 5yrs. So I'm actually trying to solve this problem. So kindly inform me whether my method and answer is correct or not.
I have attached the soln in .bmp format
Welcome to Physics Forums.
Unfortunately, no your solution is not correct. The weight of the person and the ladder does not act through the base of the ladder, it acts through the associated centre of mass. There are only two forces acting at the base of the ladder: the frictional force and the normal reaction force.
Thanks for replying :-)
So, in that case what force makes the base of the ladder to move away from the wall.
Is the normal force making the ladder to move away from the wall? I think it will be perpendicular to the floor and base of the ladder... rite??
The base of the ladder will move away from the wall if the torque created by the frictional force is not sufficient to balance the torque created by the weight of the person and the ladder.
  • · Replies 20 ·
26K
