The discussion revolves around the cohesive force of water between two lexan plates, exploring the effects of atmospheric pressure, buoyancy, and adhesive forces in various scenarios. Participants examine the implications of different shapes and seals on the net forces acting on objects in air and water.
- Exploratory, Technical explanation, Debate/contested, Conceptual clarification
- Some participants discuss the net forces acting on a book resting on a table, considering atmospheric pressure and the effects of surface roughness.
- Others propose that the buoyant force depends solely on the volume of displaced air, regardless of the object's shape, assuming no perfect seal.
- A few participants suggest that the net upward force can be approximated by the difference in pressure across the surfaces of the object.
- There are inquiries about how sealing parts of an object would affect the net force, with some suggesting that the net force may not be upwards if there is a significant area difference.
- Participants explore the concept of adhesive forces in relation to a cup on a glass table, questioning whether the sticking force is due to pressure or adhesion.
- One participant mentions the difficulty in finding a table of values for the cohesive force of water and shares their experimental approach to testing the pull-out strength of lexan plates with water in between.
Participants express varying views on the effects of atmospheric pressure, buoyancy, and adhesive forces, with no consensus reached on the cohesive force of water or the implications of sealing on net forces.
Participants acknowledge the complexity of calculating adhesive forces and the limitations of their assumptions regarding air density and pressure gradients. The discussion also highlights the challenges in obtaining empirical data for cohesive forces.
