What Is the Cost to Operate a Transistor Radio for 300 Hours on Household Power?
  • Thread starter Thread starter wakefreak90
    Transistor
The discussion centers on calculating the cost to operate a transistor radio for 300 hours using both battery power and household electricity. The battery costs $0.55 and provides a cost of approximately $3.82 per kWh. For household operation, the radio consumes 518,400 J over 300 hours, translating to 0.144 kWh. At a rate of 6 cents per kWh, the total cost to operate the radio for 300 hours is about 0.86 cents. The calculations emphasize the importance of unit conversions and proper energy measurement.
wakefreak90
**Transistor radio/kWh problem**
A transistor radio operates by means of a 10.0 V battery that supplies it with a 48 mA current.
(a) If the cost of the battery is $0.55 and it lasts for 300 h, what is the cost per kWh to operate the radio in this manner?
3.819 dollars/kWh
(b) The same radio, by means of a converter, is plugged into a household circuit by a homeowner who pays 6¢ per kWh. What does it now cost to operate the radio for 300 h?
? cents
I got Question A but I have tried everything on Question B and I do not understand what I am doing wrong. For some reason, I think it is easier than what I'm trying to do.
Please help!
Work out the number of kilowatt hours and multiply by 6.Note that the question gives the current in mA and not A and note also the the power must be expressed in kW and not W.
So if one kWh = 3.6E6 J, and the total energy is 518,400 J..
(3.6E6)/(518400) = 6.9444
--> (6.9444)(6) = 41.666
Is 41.666 cents the answer? I only have two more tries left and I don't want to get it wrong. I'm not sure if those are the correct unit conversions
W=10*48/1000
kW=above/1000
kWh=above*300
cost=above*6
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
