KurtLudwig
- 146
- 31
In particle physics there is usually a cross section for a particular particle . I came up with a cross section of 1.07 x 10^-42 m^2 for a graviton.
The cross section for a graviton has been calculated to be approximately 1.07 x 10^-42 m^2, with further discussions revealing a more refined value of 8 x 10^-65 cm² as per Freeman Dyson's paper "Is a Graviton Detectable". The scattering cross section of a graviton on a proton remains a topic of inquiry, with current theories suggesting interactions are too weak to be experimentally detected. The effective field theory of gravitons is proposed as a means to compute these interactions, although it is acknowledged that this theory breaks down at short distances and is not renormalizable.
PREREQUISITESPhysicists, cosmologists, and students of particle physics interested in the theoretical underpinnings of graviton interactions and the implications for quantum gravity research.
Amazing. How did you do that?KurtLudwig said:In particle physics there is usually a cross section for a particular particle . I came up with a cross section of 1.07 x 10^-42 m^2 for a graviton.
No there isn't. There is a cross section for scattering of one particle on another.KurtLudwig said:In particle physics there is usually a cross section for a particular particle .
Things like that have been calculated, but I don't know the result.KurtLudwig said:Then what is the scattering cross section of a graviton on a proton?
Yes, exactly.KurtLudwig said:Does the scattering cross section have to do with the particles interacting?
Demystifier said:Things like that have been calculated, but I don't know the result.
KurtLudwig said:Do physicists have a tentative theory on how a gravitons interact with a protons, neutrons or maybe directly with quarks?
KurtLudwig said:Can the interactions be detected by observing the velocities of two stars which are far away from any other stars and the center of our galaxy? Can a sensitive torsional pendulum be used to measure weak gravitational interactions?
@Greg Bernhardt do we offer an award for super-awesome understatements? :)king vitamin said:one part in ##10^{90}##, which is far smaller than any precision we can obtain.
Unless, of course, you consider a wave packet with finite width.Vanadium 50 said:It's infinite.![]()
https://publications.ias.edu/sites/default/files/poincare2012.pdfIf we imagine the whole mass of the Earth to be used as a graviton detector, with the cross-section (20) per electron and the flux (23), the counting-rate is 2.4 × 1017 per second. If the experiment continues for the life-time of the sun, which is 5 billion years, the expected total number of gravitons detected will be 4. The experiment barely succeeds, but in principle it can detect gravitons.
As you would know, the standard theory of gravity is Einstein's general relativity. That is a geometric theory in which "spacetime tells matter how to move; matter tells spacetime how to curve" (John Wheeler).KurtLudwig said:Do physicists have a tentative theory on how a gravitons interact with a protons, neutrons or maybe directly with quarks? I assume that gravitons travel through space similar to photons. Gravity only pulls baryons together, it never repels. Is this correct?
mitchell porter said:As you would know, the standard theory of gravity is Einstein's general relativity.
