What is the Difference Between AC and DC Current for Electromagnets?
  • Level: High School
  • Thread starter Thread starter eranb2
    Electromagnet Works
2 replies · 5K views · last reply
eranb2
does it have an ac or dc current?
I think I still don't understand what is the difference between ac and dc.
they both currents, both changing electric fields. (not static field since they are moving)
they both creates a magnetic field.
then what is the difference?
(DC = steady magnetic field AC = changing magnetic field) ?
to create a magnetic field, can the particles just move (steady) or they should accelerate?
thanks
Actaully, dc will work also, but under conditions.
When a dc source to an electromagnetic is turned on(or turned off) there is that period of time that the electromagnet expresses an electromagnetic field as the current intially rises(or falls). When the dc sorce is steady, no such effect occurs.
In other words, a "pulsed dc" source can work for an electromagnetic, as well as "sawtooth" or any other form of none steady dc. And though the classic "sine-wave" is normally associated with ac, it is very easy to create a dc sine-wave... which will drive an electromagnet.
Just some thoughts...
All that is needed for a magnetic field is a moving charge; if by charges accelerating you're referring to changing current, then the magnetic field also changes.
You essentially need a changing current (the result should be a changing magnetic field) whether it be AC or DC (AC is convenient because its always changing) for induced voltage.
