What is the dimension of its kernel?
  • Thread starter Thread starter Jennifer1990
    Dimension Kernel
In the discussion, the relationship between the dimensions of the kernel and image of a linear map A from vector space V to W is explored. Given that A is onto, it is established that every vector in W has a pre-image in V, which influences the kernel's dimension. The relevant equation, dim(ker A) + dim(im A) = dim V, is highlighted, leading to the conclusion that the dimension of the image, dim(im A), equals n. Consequently, the dimension of the kernel is deduced to be m - n. This relationship is crucial for understanding the properties of linear transformations in vector spaces.
Jennifer1990
Suppose that dim V = m and dim W = n with M>=n . If the linear map A : V -> W is onto, what is the dimension of its kernel?
Onto, means that every vector in W has at least one pre-image therefore, the kernel can have a maximum dimension of m?
There is a property that you can use: dim(ker A) + dim(im A) = dim V. (see http://en.wikipedia.org/wiki/Kernel_(linear_operator )) The fact that A is onto W tells you something about dim(im A), the dimension of the image of A.
ohhhhh is it m - n?
Very likely it is.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
