What Is the Displacement of the Wandering Wolf?
  • Thread starter Thread starter hotshot1kille
    Displacement
The discussion revolves around calculating the displacement of a wolf that wanders in multiple directions. The wolf's movements are described in terms of distances and angles, with a specific sign convention for direction. The attempted solution suggests using vector subtraction to find the overall displacement but results in confusion regarding the reference point. The poster seeks clarification and guidance on accurately determining the displacement. Ultimately, the need for a clear method to visualize the wolf's path and calculate the shortest distance is emphasized.
hotshot1kille
A wolf wanders 64 m [N15E], 93m[N20W], and 167 m [N]. What is her displacement?
North to South east is considered positive by my sign convention, and from south to north west, it is considered to be negative, once again by my sign convention. I've never seen problems like this before, I did make an attempt but i am getting the answer wrong.
Δ d = d3 - d2 - d1
Δd= (+ 167m [N]) - ( -93 m [N20W]) - (+ 64m [N15E])
= 324 m [N5W]
Displacement is the shortest distance between your initial distance and final distance. Try drawing the wolfs movement on a paper with the angles then draw a line between the initial distance and final distance that is the displacement
So then what point is my point of reference, and i tried it but still nothing. Can someone do it and show how they got the right answer??
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
