What is the dynamic viscosity of air?
The dynamic viscosity of air is a physical property that is primarily dependent on temperature, not velocity. Under standard sea-level conditions at 15°C, the density of air is 1.225 kg/m³. The formula for calculating dynamic viscosity is given by the equation: Dynamic viscosity = (density * velocity * length) / Re, where Re is the Reynolds number. It is crucial to note that viscosity remains constant regardless of the airfoil's velocity.
  • Understanding of fluid dynamics concepts
  • Familiarity with the Reynolds number
  • Knowledge of the relationship between temperature and dynamic viscosity
  • Basic proficiency in applying physics equations
  • Research the relationship between temperature and dynamic viscosity of air
  • Learn how to calculate Reynolds number for different fluid flow scenarios
  • Explore the effects of altitude on air density and viscosity
  • Study the implications of dynamic viscosity in aerodynamics and airfoil design
Students studying fluid dynamics, aerospace engineers, and anyone involved in the design and analysis of airfoils and aerodynamic systems.
Angelina21
Considering an airfoil (a flat plate) flying at 100 m/s under sea-level conditions, so the density is 1.225 kg/m3 and the length being 1 m, what is the dynamic viscosity of air? The problem is that I have two variables in one formula, Reynolds number and the viscosity.
Dynamic viscosity=(density*velocity*length)/Re
Likes Delta2
What is the temperature? You are aware that, under these conditions, the dynamic viscosity (a physical property of the air) is a unique function of temperature that you can look up on line, right?
The temperature according to sea level conditions is 15oC. I'm aware that it's online. But doesn't the viscosity depend on velocity? Or it's always constant, no matter the velocity?
Like I said, it's a physical property of the air, independent of anything being done to the air.
  • · Replies 29 ·
16K
