What Is the Effect of Inserting a Dielectric Slab into a Charged Capacitor?
Inserting a dielectric slab into a charged parallel-plate capacitor alters its capacitance and stored energy. The new capacitance can be calculated by treating the capacitor as two in parallel, one with half the area and the other with the dielectric constant. The energy stored in the capacitor changes due to the fixed charge, leading to a decrease in energy as the slab is inserted. The force on the slab varies as it is moved into the capacitor, and this force can be derived from the change in energy. The problem requires careful consideration of edge effects and the gradual insertion of the slab to accurately determine the force at different positions.
mXCSNT
An air-insulated parallel-plate capacitor of capacitance C_0 is charged to voltage V_0 and then disconnected from the charging battery. A slab of material with dielectric constant \kappa, whose thickness is essentially equal to the capacitor spacing, is then inserted halfway into the capacitor. Determine (a) the new capacitance, (b) the stored energy, and (c) the force on the slab in terms of C_0, V_0, \kappa, and the capacitor-plate length L.
C = \kappa \frac{\epsilon_0 A}{d} for a parallel-plate capacitor with dielectric
\kappa_{Air} = 1.0006
C = C_1 + C_2 for the equivalent capacitance of two capacitors in parallel
U = \frac{1}{2}CV^2 (energy in a capacitor)
V = Q/C
I took the capacitor to be two capacitors in parallel, one with half the area and therefore half the capacitance of C_0, the other with dielectric constant \kappa and also with half the area.
C_1 = \frac{C_0}{2}
C_2 = \frac{C_0 \kappa}{2 \kappa_{Air}}
C_{total} = C_1 + C_2 = \frac{1}{2}C_0 \cdot (1 + \frac{\kappa}{\kappa_{Air}})
And the energy is just \frac{1}{2}C_{total}V_0^2
However I know this approach is incorrect. The professor worked this problem in class, and said that such an approach would over-simplify because the potential inside the capacitor would have to jump sharply as you crossed the edge of the inserted slab. He worked through an approach where he took into account that edge effect. Unfortunately I didn't write it down. Also, I am mystified how to get the force on the slab--I guess the slab must pick up some charge, but I don't know how.
We also have Gauss' law \oint_S \vec{E} \cdot d\vec{A} = \mu_0 Q_{enclosed}, and I remember the professor saying something about considering the situation as the slab is gradually moved in from one side a distance x, but I don't have any ideas. I still don't see what causes any force on the slab, unless it means the force on the slab while it is being moved (since the stored energy must increase and the only source for it is the motion of the slab).
Oops... never mind I was wrong.
The new capacitance is correct. In this situation charge is fixed. The old and new capacitor have the same charge... not the same voltage. So use that to calculate the energy stored in the new capacitor...
The force changes as the slab goes into the capacitor... does the question ask for the force at a particular point, or is it asking for a formula for the force at all points?
I think the question is asking for the average force on the slab... The capacitor loses energy... take the final energy - initial energy... That is the negative of the work done by the capacitor on the slab...
ie : -Fav*(L/2) = final energy - initial energy
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
