What is the efficiency of the engine?
  • Thread starter Thread starter bluemoon
    Efficiency Engine
To determine the efficiency of an engine pulling a 10 kg load to a height of 4 meters, the correct work done is calculated as approximately 400 joules. The efficiency formula is efficiency = (work done / work required) * 100, where the work required is 500 joules. Confusion arose over the values used in calculations, with participants questioning the accuracy of the numbers presented. It was emphasized that showing all steps in calculations is crucial for clarity. The discussion highlights the importance of accurate numerical values and proper equation usage in efficiency calculations.
bluemoon
f an engine must do 500 joules of work to pull a 10 kg load up to a height of 4 meters, what is the efficiency of the engine?
So that's
400/50,000
which gives me 0.008
Does that mean the efficiency is 8%?
where did you get your numbers from?
50k?
400?
None of this makes any sense.
Work done: 10kg*9.8N/kg*4=appx 400J
efficience= work done/500 * 100
400J is not correct, please write down the correct numerical value.
Your second line is not correct.
efficiency = work needed ideal/ work actually required
It is always less than one.
Okay for my first line, I got 24.5
and I don't know how I'm messing up on my second line. ??
where are you getting these number from?
You need to start showing me your work and not just some random numbers you are calling approximations.
Bluemoon : Please write down the equations before plugging in numbers.
  • · Replies 19 ·
  • · Replies 35 ·
  • · Replies 74 ·
  • · Replies 20 ·
14K
