What is the equation for Water Expansion when
  • Thread starter Thread starter infinite_gbps
    Expansion Water
The equation governing water expansion due to temperature changes is defined as dV / Vo = 3*alpha* dT, where dV represents the change in volume, Vo is the original volume, and dT is the change in temperature. The coefficient of thermal expansion for water at 20 degrees Celsius is approximately 207E-6 per °C. While the initial relationship appears linear, the provided chart indicates that the expansion may exhibit nonlinear characteristics at different temperatures. For precise calculations, users should refer to the linked water expansion calculator for practical applications.
  • Understanding of thermal expansion concepts
  • Familiarity with basic thermodynamics
  • Knowledge of volume and temperature relationships
  • Ability to interpret scientific equations and charts
  • Research the Coefficient of Thermal Expansion for various liquids
  • Explore nonlinear thermal expansion equations
  • Learn how to use calculators for thermal expansion in practical scenarios
  • Investigate the effects of temperature on the physical properties of water
Scientists, engineers, and students studying thermodynamics or fluid mechanics, particularly those interested in the thermal properties of water and its applications in various fields.
infinite_gbps
What is the equation for Water Expansion when ...
Hi all,
I know that water expands when heated above room temperature.
I just need to know what equations govern this expansion. For example, let's say I add x amount of heat, then water expands x amount.
Is it linear? Is there a maximum amount?
Any links on reading would help.
Coefficient of thermal expansion
Ok, I found this equation on wikipedia.
T: temperature
V: Volume
It gives in a chart for water that 3*alpha is 207E-6 per C at 20 degrees C.
Does that mean that the change in volume (dV) will be 3*alpha*dT*Vo? That seems pretty linear.
The link here: http://www.plumbset.co.uk/waterexpansion.htm
gives a calculator for water expansion and the chart they give (if you click the link) looks nonlinear.
If I am trying to come up with a equation that gives me the amount of expansion if given the temperature what must I do.
  • · Replies 66 ·
  • · Replies 19 ·
