- 4,508
That configuration is the well-known Counterflow Heat Exchanger. Its advantage is that the hottest part of the hot side heats the hottest part of the cold side fluid.Ken Fabian said:The designers may prefer hot coming down a coiled heat exchanger pipe, working with rather than against the (separate) convection within the heating fluid
If both fluids are flowing in the same direction thru the heat exchanger, then the cold fluid can typically get only as hot as the average of the hot and cold sources. (unless the hot side is grossly over-provisioned)
https://web.mit.edu/16.unified/www/FALL/thermodynamics/notes/node131.html
Cheers,
Tom
