What Is the Equation of State for a Gas Given Its Gibbs Function?
anothersivil
*1* The Gibbs function G(T; P) of a certain gas is:
G = nRT ln P + A + BP + (1/2)*CP^2 + (1/3)DP^3
where A, B, C and D are constants. Find the equation of state of the gas.
G = nRT ln P + A + BP + (1/2)*CP^2 + (1/3)*DP^3
I think I have a solution for this, but it seemed to be too easy.
The definition for Gibbs free energy is defined to be:
1) G = U - TS + PV and 2) dG = -SdT + vdP
solving 2) for dG/dP yields: dG/dP = -SdT/dP + V 3)
I thought to take 3) at constant temperature yielding: dG/dP = V
Now, taking dG/dP at constant T from the given formula yields:
dG/dP =nRT/P + B + CP + DP^2 4)
Setting 3) = 4) and solving for PV yields:
PV = nRT + PB + CP^2 + DP^3
That just seemed too easy for me >.>
The second part of this homework is:
Consider a spring which follows Hookes law; namely the displacement x from equilibrium
position is proportional to the tension X when it is pulled at a constant temperature. The spring constant is temperature dependent, k = k(T). Determine the free energy F, the internal energy U, and the entropy S, as a function of T and x. Neglect the thermal expansion of spring. Use F0(T) ´ F(T; x = 0); U0(T) ´ U(T; x = 0); S0(T) ´ S(T; x = 0) where necessary.
k = k(T)
F[0](T) = F(T; x = 0)
U[0](T) = U(T; x = 0)
S[0](T) =S(T; x = 0)
where the brackets denote subscripts
The force of the spring can be obtained by: F = -k(T) * x
And the work: W = int(-k(T) * x) dx = -(1/2)*k(T)*x^2
and dW = k(T) *xdx
Using the first law of thermodynamics: dU = dQ - dW, so
dU = dQ + k(T)*xdx
The elongation of the spring would add another term to your energy equation:
U=TS-PV+Fx=TS-PV+k(T)x^2
F=U-TS=-PV+k(T)x^2
S=-\left(\frac{\partial F}{\partial T}\right)_V=-\frac{\partial k(T)}{\partial T} x^2
Does this help?
That makes sense to me, but what about those 3 initial conditions? This just seems too easy to me >.>
What do I do with those?
I cheated a bit by ignoring the temperature dependence of PV and by setting my energy baseline at \mu\,N. The initial conditions make these constants go away anyway. Wouldn't you end up with, for example,
S=S_0-\frac{\partial k(T)}{\partial T} x^2
I'll leave the rest for you.
Thanks a bunch! This helps alot! :P
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
