What is the hottest temperate we can grow food at?
  • Thread starter Thread starter AtomicJoe
    Food
35 replies · 13K views
AtomicJoe
Is there a maximum temperature at which food can be grown and if so what is it?
I know there is a not much food in the Sahara desert but is this because it is too hot?
I only ask because that desert is not as near the equator as say the Brazilian rain forests
which I presume might be hotter (not 100% sure on this one so bear with me :wink:).
Anyhow I am rambling, is there a max temperature above which no food can be grown and if so what is it?
As a rule of thumb I would guess things tend to grow better with higher temperatures but when they get too hot obviously this no longer holds.
So is there a hottest temperature and also is there an 'optimum' one, I presume there must be, just like in Goldilocks and the three bears ie not to hot not too cold but just right. :smile:
I tried googling but I could not find much, apart form for growing Marijuana plants, which is probably not a great food stuff as it is normally used an illegal drug.
Depends what you mean by food, I suppose: I would not care to live on extremophile scum, but a genetically engineered variant could be okay...
Lack of water, which is why you see trees and plants flourishing where there is water, such as an oasis
I only ask because that desert is not as near the equator as say the Brazilian rain forests.
Lots of water.
Sorry I don't have time to research studies on heat and plants right now, since water would be a factor.
Atomic Joe,
Here is a good start, http://www.thehottestpepper.com/how-to-grow-bhut-jolokia-seeds.html" peppers.
Bhut Jolokia requires soil temperatures to be between 75°F and 90°F for proper germination. You may need to supply bottom heat with the aid of a propagation mat.
and http://forums.gardenweb.com/forums/load/pepper/msg03130328621.html":
I noticed 90 degrees F and above would cause flower drop.
Without flowers, no peppers, so 90 degrees F when flowers are present, and no more than 95 degrees F when peppers are forming. That is a start at least, anyone got any higher temps for flower and fruit formation for other fruit ? I would be surprised if these peppers are not top or close to top.
Rhody... :devil: :biggrin:
P.S. Does your question revolve around global warming, and food shortages ?
Don't forget that it was much hotter in the past and plant life flourished. It's cold weather that we need to worry about.
Lots of water.
Well you can assume there is water available I think, I don't think there is much point in growing stuff in a desert.
I would agree with you there, it seems to be that frost is the big killer of crops.
I think most countries would benefit from higher temperatures, eg in the UK you can only grow fruit and veg for about 8 months, in other countries which are less seasonal the growing season is much longer.
It may be all year round in some but I am not sure.
I guess the only problem might be soil exhaustion, so you would need more fertiliser.
Indeed, and it seem that they were great conditions for food growth judging by the size of some of the animals.
Wouldn't it be great for agriculture if we had those kinds of temperatures!
We could grow our own dinosaurs!
AtomicJoe, you are not making any sense at all.
Why do things not grow in the desert?
Because there's no water.
OK, let's assume there's lots of water.
Is it heat that makes things grow?
No, it's water.
So if it's really hot, we'll be able to grow bigger things!
Fail.
No, it's water.
Fail.
It is not just water, it is the soil type, You can't grow stuff in sand because there are no nutrients.
Anyway you are wrong about water making things grow, you don't see much growing in the Arctic or Antarctica do you?
Heat makes thing grow faster, that is the whole point of it.
There are no nutrients because nothing has been living in the soil for millenia.
Where do you think nutreints come from?
:rolls eyes :
Sorry. Didn't think I'd have to spell this out. liquid water.
The whole point of what?
You logic is wonky. Tiger and rainforests occur in the same place too. Does that mean tigers cause rainforests? Correlation does not imply causation.
Sunlight is what makes plants grow. They're photosynthetic. Plants will grow happily in low temps if provided enough water and sunlight.
is there any proportionality between temperature and food? but stil many food products obtained in the area s where temperature is more can't be obtained other places?///
Lots of water.
do water only matters??
Again, it is not the temperature in these climates that is important; it is the sunlight.
It is certainly primary.
Plants (and by extension, the rest of the food chain) need water, nutrients and sunlight.
:rolls eyes :
Ha ha, well that is a bit of a cop out isn't it?
What do you think sunlight does?
Surprise surprise it increases the temperature!
Plant growth is a chemical reactions and chemical reactions generally go faster (more growth) at higher temperatures.
Obviously there is an upper limit to that but for the Earth the 'dead' zone is the cold areas not the warm areas.
In that case wouldn't a better question be at what temperature are plant enzymes denatured at?
It might be if I knew what denatured mean but I don't so it won't.
Enzymes are catalytic proteins which are vital for the vast majority of metabolic reactions. In humans they have an optimum temperature at around 40 degrees.
The sun light hitting plants allows for photosynthesis. Increasing the temperature will not necessarily help, like all evolved organisms different species will have different optimum temperatures, a cactus is unlikely to survive well in the tundra.
Biology is not simple enough for one to simply say "if we increase the temperature things will grow faster".
Different plants will need different things but all will need optimum amounts of heat, nutrients, liquid water and sunlight.
Wow that is interesting
The average temperature of the Earth is only 15C, so we are well below the optimum range.
I wonder how much we could produce at 40C and whole 25C higher?
We would be drowning in food!
I was going on the basis that temperate increases the rate of chemical reactions and plant growth is a chemical reaction.
For sure you grow far more in green house don't you?
And that is because it is hotter, not because you get more sunlight, cos you don't.
The point I am making is that on the whole warmer temperatures produce more food, that pretty apparent in there number of greenhouses isn't it.
Without stating the obvious you very rarely see a gardener installing a cooling system, indeed if you have please let me know bout it cos I'm interested. Please supply a link.
We would be drowning in food!I was going on the basis that temperate increases the rate of chemical reactions and plant growth is a chemical reaction.
I think you misunderstood me. This is the optimum temperature for enzyme activity, not growth. It is simplistic to think that if the environment was this temperature the plant would grow better. In addition increased enzyme activity won't necessarily lead to faster growth, in biological systems processes have to happen at just the right speeds at just the right times.
There are many other processes in an organism that will have different optimum temperatures, also the reason organisms are hotter than the environment is because of chemical activity, this heat needs to be expelled into the cooler air.
Greenhouses help some types of plant, they also allow you to regulate the nutrition and water intake. Greenhouses will not help you grow every plant because as I said different species have evolved to different temperatures. If you wanted to grow an Oak tree in the Sahara you would need a cooling system.
You need to go and learn more basic biology, it seems that you have a simplistic understanding (which is not your fault, we were all beginners sometime). In the majority of situations you can't just increase one input and expect a proportionally increased output.
So by your logic deserts such as sahara should be a paradise for agriculture. They are some of the hottest regions in the world.
I think you slightly misunderstand, I am talking about growing food, I am not demanding a particular plant. Anyone will do and the hotter it is the more food you will get by and large.
By the way you can grow oak in the Sahara and no cooling system is needs.
Look here is one.
http://www.123rf.com/photo_4813568_a-huge-old-oak-tree-in-a-tropical-forest.html
Look here is one.
Any food plant will do? Do you realize how many different species of plant we grow for food? Again though plants have evolved to grow at optimum temperatures, if we built a big greenhouse over some corn and cranked up the temp to 40 degrees there's no reason to think that it would grow faster or larger. What references do you have to support the claim "the hotter it is the more food you will get by and large"?
That picture is not of an oak tree in the Sahara.
You have been told several times that you are wrong and people have been very generous in giving you correct information which you continually choose to ignore. I suggest that you stop the trolling and do some research and don't post again until you have an acceptable scientific source to back up your claims. It will do you a lot of good and will allow you to ask better questions, if you still have any.
I was about to tell you in how many ways the above is flawed but it seems Evo has beat me to it.
Joe, seriously, you can learn things here. But you won't if you insist on following your own internal, convoluted logic.
Thanks for telling me I am wrong.
Now for me to learn it would be helpful to tell me precisely which statements I have made are wrong and also if you would be so kind why they are wrong.
Telling me I am wrong is a very broad sense is not helpful as I have often made several statements and you need to be more specific if you want to teach me anything.
As has been said by many people, different plants have different requirements. All plants require optimum amounts of; light, soil temperature, air temperature, different minerals, concentrations of minerals and water. The specific amounts differ from plants to plants.
Therefore increasing just one variable (unless increasing it pushes it towards optimum) will not lead to greater growth.
What you have done wrong is to assert that increasing heat leads to increased growth, not only because the statement is wrong but because you have said it with no references. A bigger mistake you have made is to ignore things that people have written. For example in post 21 you quote me and in that quote I say that biology is not simple enough that you can just increase heat and expect more growth yet you claim this from my quote. Repeatedly people have said that there are many requirements for plant growth each with different optimums but you did not address this.
I would advise that next time you wish to start a thread or post first you do some background research to acquire some references. Then respond to what people say by reading what they say and taking it on board.
OK something concrete there.
Now can you then explain why a tobacco farmer in Mississippi can grow two crops in a year whilst one in Canada can only grow one? It seems to me it is because it is hotter in Mississippi, or have I overlooked something?
Regarding references, I seem to be the only one who has posted anything external to the site to back up my posts.
I mean you have provide no references that I am aware of so can I ask why you do not provide reference?
I didn't post references for something such as two crops in warmer Mississippi because I did not think anyone would dispute
that.
