What is the Isomorphism between Groups and its Implications?
5 replies · 3K views
Boorglar
Prove or disprove the following assertion. Let [itex]G[/itex], [itex]H[/itex], and [itex]K[/itex] be groups. If [itex]G × K \cong H × K[/itex], then [itex]G \cong H[/itex].
[itex]G × H = \left\{ (g,h): g \in G, h \in H \right\}[/itex]
I don't even know whether the statement is true or false... I tried looking in both directions but to no avail.
For a counterexample, I figured that at least one of the sets would have to be infinite, otherwise G and H would have the same number of elements and it would be harder for them not to be isomorphic. I considered the sets:
[itex]\left\{0\right\} × Z[/itex] and [itex]Z_{2} × Z[/itex] with the isomorphism being:
[itex]\phi( 0, 2n ) = ( 0, n )[/itex] and [itex]\phi( 0, 2n + 1 ) = ( 1, n )[/itex]. Then it is well-defined, one-to-one and onto. But it does not preserve the operation because [itex]\phi( 0, 1 ) + \phi( 0, 1 ) = ( 1, 0 ) + ( 1, 0 ) = ( 0, 0 )[/itex] while [itex]\phi( (0,1) + (0,1) ) = \phi(0,2) = (0,1)[/itex].
I still think someone could tweak the definition a bit to make it an isomorphism, but of course I am not sure.
As for proving the theorem is true, I don't even know how to start. I considered the following mapping [itex]\phi : G → H[/itex] defined as [itex]\phi( g ) = h[/itex] where [itex](g,e_{K}) → (h, k')[/itex] under the isomorphism between [itex]G × K[/itex] and [itex]H × K[/itex].
Then I proved [itex]\phi[/itex] is well-defined and preserves the operation. But I cannot prove that it is one-to-one, nor onto. The problem is that I have no reason to believe that if [itex]g_{1} ≠ g_{2}[/itex] then [itex](g_{1},e_{K}) → (h_{1}, k_{1})[/itex] and [itex](g_{2}, e_{K} ) → (h_{2}, k_{2})[/itex] where [itex]h_{1}≠h_{2}[/itex].
On the other hand, no other natural candidate for an isomorphism comes to mind, so I am completely stuck here. If someone could, not give me the whole answer, but just point to the right direction? Because I may be looking somewhere completely unrelated :(
The group ##\mathbb{Z}_2\times \mathbb{Z}## has an element of order ##2##, the group ##\{0\}\times \mathbb{Z}## doesn't. So the groups are not isomorphic.
You're however correct that the statement is false. Take the following group as ##K##
[tex]\mathbb{Z}^{\mathbb{N}} = \{(x_n)_n~\vert~x_n\in \mathbb{Z}\}[/tex]
with the usual operations. Can you find the right ##G## and ##H##?
Is that the set of all infinite sequences of integers?
Ok yes! I finally got it:
Let G be {0} and let H be Z. Then define [itex]\phi[/itex] to be:
[itex]\phi( (0, (a_{1}, a_{2}, ... ) ) ) = ( a_{1}, (a_{2}, a_{3}, ... ) )[/itex] obtained by left-shifting the sequence. It is obviously well-defined. It is one-to-one because if two left-shifted sequences are equal, then adding a zero in front keeps them equal. And any sequence can have a zero added to it so the mapping is onto. The operation is preserved because:
[itex]\phi( (0, (a_{1}+b_{1}, a_{2}+b_{2}, ... ) ) ) = ( a_{1}+b_{1}, (a_{2}+b_{2}, a_{3}+b_{3}, ... ) )[/itex] [itex]= ( a_{1}, (a_{2}, a_{3}, ... ) ) + ( b_{1}, (b_{2}, b_{3}, ... ) ) = \phi( ( 0, ( a_{1}, a_{2}, ... ) ) ) + \phi( 0, ( b_{1}, b_{2}, ... ) ) )[/itex]
Thanks for the help. I don't think I would have thought of that anytime soon :P
By the way, are you really 19? Because that's my age too but you seem so much more knowledgeable!
