What is the issue with log scales and plotting values less than 1?
The discussion centers on the challenges of plotting values less than 1 on a logarithmic scale in a programming assignment using JFreeChart. When markers are added in linear scale, they appear correctly, but in logarithmic scale, clicks near zero result in unexpected shifts to the right. The logarithm of values between 0 and 1 yields negative results, complicating the placement of markers. Suggestions include adjusting the origin of the plot to avoid negative logarithmic values and recognizing that there is no (0,0) point in a log scale. Understanding the logarithmic function's behavior is crucial for accurately translating mouse click coordinates to the plot.
lgarcia12
I am working on a homework for a programming class. We have to create a Logarithmic plot and add to it a marker when the program is running on the click of the mouse. That is NOT the problem :) , in fact, that's very simple!
My problem, however, is with the scale. When my plot is in linear scale it adds the marker right where it should. By that I mean that if I click on point (1,2) it adds my marker on (1,2). Now, when I switch to logarithmic scale, if I click on (0,0) it adds the marker on (1,1). If I click on values greater than 10, it adds the marker at the place where I clicked. But when my values are lower than 10, the marker is shifted to the right. How do I solve that problem? I already tried converting the values I get from my mouse-click event to logarithmic values and they are wrong. In fact I get negative numbers when the values are lower than 1; so the marker is shifted to the left. I am not good at all with log scales; so, please help me!
It's difficult to know what is happening without seeing your code. Some ideas:
The logarithm of 1 is 0, so when you click on (0,0) you are really clicking in (log 1, log 1). Anyway, you cannot have the poin (0,0) in a log scale, since log 0 = - infinity.
The logarithm of a number between 0 and 1 is negative.
The code is in Java. We are using a library called JFreeChart to create the chart. Here is the click event where everything happens:
Code:
public void mouseClicked (MouseEvent e)
    if (SwingUtilities.isRightMouseButton (e))
      return;
    if(pointerAdded)
        return;
    //These return the x,y position on the screen or screen location
    int x = e.getX ();
    int y = e.getY ();
    // Translates a screen location to a Java2D point.
    Point2D p = translateScreenToJava2D (new Point (x, y));
    //create Plot object
    XYPlot plot = getChart ().getXYPlot ();
    //get the chart renderer
    ChartRenderingInfo info = getChartRenderingInfo();
    //The area where the clicked occured
    Rectangle2D dataArea = info.getPlotInfo().getDataArea();
    //Get the plot coordinates of where the event ocurrs
    double xx = plot.getDomainAxis ().java2DToValue (p.getX (), dataArea, plot.getDomainAxisEdge ());
    double yy = plot.getRangeAxis ().java2DToValue (p.getY (), dataArea, plot.getRangeAxisEdge ());
    //Add the custom annotation
     CircleDrawer cd = new CircleDrawer(
            Color.RED, Color.BLACK , new BasicStroke(1.0f), null);
    XYAnnotation bestBid = new XYDrawableAnnotation(
    		xx, yy, 11, 11, cd
    this.renderer.addAnnotation(bestBid);
    pointerAdded = true;
    repaint ();
As you can see, the points come out straight from the plot.
About what you say, you're right and I had noticed that before. Now, my question is, how do I go from (log 1, log 1) to my linear numbers so that I can get the right position?
I just did a quick test to see what the event returns. As I click closer to 0, it results in a number sifted more and more to the right. I am only showing the x coordinate since the y have exactly the same results. Also, the resulting values are approximate since I did not zoom in close enough in the plot to click exactly on the number.
Click on Result
10 10
9 9.118812375
8 8.223735874
7 7.307858871
6 6.444623616
5 5.50047321
4 4.624704838
3 3.70626008
2 2.820675981
1 1.90761842
0 1.003834079
it looks like a function, I just don't know how to find it. I think that if I find it, I can solve my problem.
Thanks
Click on Result
10 10
9 9.118812375
8 8.223735874
7 7.307858871
6 6.444623616
5 5.50047321
4 4.624704838
3 3.70626008
2 2.820675981
1 1.90761842
0 1.003834079
Thanks
This is really weird. It is not a logarithmic function. if you call Y the vector of clicked points and X the vector of results, you obtain:
y = 1.1104x - 1.1234.
can you post the code? I have an idea, but don't know if it defeats the purpose or not.
Would flooring the result be a work around?
Matt
The problem is with your labelling. There is no point (0,0) in a log plot. If you must plot numbers that are less then 1, you should put your origin at (o.1, 0.1) or (0.01, 0.01). Remember that the distance between 0.1 and 1 is the same as from 1 and 10. See anex graph. That is what makes the linear relationship between clicked point and result skewed.
