What is the issue with my step function code and how can I fix it?
Homework Helper
I wrote some code that is supposed to give me the step function:
Matlab:
function y=step_fn(x,a,b)
%This is the step function, given a range from a to b, it wil produce a
%function which is 1 from a to b and zero otherwise.
L=length(x);
y=zeros(1,L);
n=find(x<=a,1,'last');
if (b==max(x))
    m=L;
else
    m=find(x>=b,1,'first');
end
if (n==1)
    y(n:m-1)=1;
else
    y(n+1:m)=1;
end
This all looks good, however when I do the following:
Matlab:
x=linspace(0,5,500);
D=1.5*step_fn(x,0,2)+2*step_fn(x,2,4)+0.5*step_fn(x,4,5);
I get the attached plot. I don't quite understand . Does anyone understand where I am going wrong?
I get similar odd results with the smooth approximation using the erf function.
Why not use Matlab to debug it by looking at the output of each line of code?
This way you can localize your error to perhaps a single line or more and research that line.
You are checking the boundaries using <= and >=, meaning that both extremities get included. In other words step_fn(x,2,4) returns 1 for x=4, and step_fn(x,4,5) also returns 1 for x=4, so the two get added up. The only reason it doesn't happen at x=2 is that , for some reason, you decided to exclude the last point if the interval starts at the first point in x, so step_fn(x,0,2) returns 0 for x=2.
You need to decide which of step_fn(x,a,b) or step_fn(x,b,c) equals 1 when x is exactly b (or set step_fn(x,a,b) to return 0.5 when x is exactly a or b).
BTW, an easy MATLAB step function looks like this:step_fn = @(x,a,b) x>=a & x<=b;
