What is the Kernel, Nullity, Range, and Rank of T given a specific matrix A?
  • Thread starter Thread starter hachi_roku
    Kernel
hachi_roku
let T: R^4 --->R^3, where T(v)=A(v) and matrix A is defined by
A = [2 1 -1 1
1 2 0 5
4 -1 1 0
Find kernel of T, nullity of T, range of T and rank of T
ok. ker(T) = Null(A)
[2 1 -1 1][v1]= [0]
[1 2 0 5] [v2]= [0]
[4 -1 1 0][v3] = [0]
[v4]
simplifying using gauss jordan:
1 0 0 1/6 [v1] [0]
0 1 0 29/12 [v2] = [0]
0 0 1 7/4 [v3] [0]
[v4]
v1 + 1/6V4 = 0
V2 + 29/12v4 = 0
v3 + 7/4v4 = 0 so [ -1/6v4]
[-29/12v4] V all real
[-7/4v4]
[v4]
range and rank i got 3
is this right?
anyone?
First, don't get upset if someone doesn't respond within four hours!
Second, it is easy to check for yourself if you have the kernel right: Take A of each of the vectors in the kernel and see if it is 0. Frankly, I don't know what by mean by
"[ -1/6v4]
[-7/4v4]
[v4]"
Do you mean that the kernel is the one dimensional subspace of R4 spanned by the single vector <-1/6, -12/12, -7/4, 1>?
Finally, no, the nullity and range cannot both be 3. By the "rank-nullity theorem", rank and nullity must add to the dimension of the domain space, in this case, 4.
If you are saying that the kernel is spanned by that single vector, then the kernel has dimension 1, so the nullity is 1, and the rank is 4-1= 3.
yes that's what i meant by writing that answer, so to check this, i take the matrix of that and see if it is zero?
"[ -1/6v4]
[-7/4v4]
[v4]"
Once again, "take this matrix and see if it is 0" makes no sense. Take what matrix and see if what "makes no sense"?
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
