What is the length of the vibrating section of the violin string?
  • Thread starter Thread starter Deviatorz
    Standing wave Wave
The discussion centers on calculating the length of the vibrating section of a violin string based on given parameters, including tension, linear density, and wavelength. The vibrating section refers to the length of the string that produces standing waves, which varies with the harmonic being played. To solve the problem, one must determine the harmonic and apply the appropriate formulas, including the relationship between frequency, tension, and linear density. A common mistake noted was not converting linear density from grams per meter to kilograms per meter, which affects the calculations. Ultimately, the correct length of the vibrating section is determined to be 28.9 cm.
Deviatorz
A particularly beautiful note reaching your ear from a rare Stradivarius violin has a wavelength of 39.1 cm. The room is slightly warm, so the speed of sound is 344 m/s.
If the string's linear density is 0.620 g/m and the tension is 160 N, how long is the vibrating section of the violin string?
T = 160N
Linear Density = 0.62g/m
Wavelength of violin string = 0.391m
Speed of sound in warm room = 344m/s
m = 1?
v = \sqrt{\frac{T}{\mu}}
v = \lambda\timesf
I all know is to find the velocity of the string first which is the square root of 250 or about 15.811m/s. I am unsure of what to do next. Also, what is the "vibrating section of the violin string"? I am unsure of what that is. Thanks in advanced.
T = 160N
m = 1?
v = \lambda\timesf
The vibrating section of the string is that of the standing wave, i.e. the bit better the bridges of the violin. This length is dependent on the note played. To solve this problem you need to figure out which harmonic the string is vibrating at.
I still don't quite get what the "vibrating section" of the violin string is. Are you saying that it is the length of the string; which makes no sense. I think the harmonic for stringed instruments is one or m = 1. Somewhere in between I have to use this formula:
f1 = \frac{1}{2L}\times\sqrt{\frac{T}{\mu}}.
With stringed instruments you have as many harmonics as there are notes, effectively that is the physics behind it. A violinist can place his finger very lightly on a string so that it divides the string into half. He will hear a harmonic (the note an octave higher than the open string). By placing his fingers in other places he can get more harmonics, e.g by touching the string a quarter of the way down he gets the next harmonic.
Sorry for the late reply, the way I approached the question was correct. My answer was incorrect because the linear mass density in the question was in g/m while I needed to convert to kg/m. This question took me hours to figure out, I was sure the way I was doing was correct.
For future references, the answer to this question is 28.9cm.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
