What is the magnitude of the angular momentum of the bar?
The magnitude of the angular momentum of a rigid, uniform bar rotating about its midpoint is calculated using the formula L = Iω, where I is the moment of inertia and ω is the angular velocity. For a bar of mass m and length b, the moment of inertia is I = 1/12 * m * b². The relationship between linear speed v and angular velocity is given by v = ω(L/2), which applies to each endpoint of the bar. The final expression for angular momentum is L = 1/6 * mbv, confirming that the linear speed does not need to be doubled for both endpoints.
  • Understanding of angular momentum and its formula L = Iω
  • Knowledge of moment of inertia for a rigid body, specifically I = 1/12 * m * L²
  • Familiarity with the relationship between linear speed and angular velocity, v = ωr
  • Basic concepts of rotational motion and rigid body dynamics
  • Study the derivation of the moment of inertia for various shapes, including rods and disks
  • Learn about the conservation of angular momentum in closed systems
  • Explore the effects of varying mass distribution on angular momentum
  • Investigate real-world applications of angular momentum in mechanical systems
Students studying physics, particularly those focusing on mechanics and rotational dynamics, as well as educators teaching concepts related to angular momentum and rigid body motion.
Toranc3
A rigid, uniform bar with mass m and length b rotates about the axis passing through the midpoint of the bar perpendicular to the bar. The linear speed of the end points of the bar is v . What is the magnitude of the angular momentum of the bar?
L=Iw
I=1/12(ML^(2) This L is the length.
v=wr
L=1/12*m*B^(2)*w
v=wr
it says that the linear speed of the bar at the end points is v
When I first read that I automatically thought that I would have to double v=wr because it has two endpoints. However, that is wrong. Why is it that I am only supposed to use a single v=wr?
Hi Toranc3! :smile:
Toranc3 said:
v=wr
v = ωr applies to the speed v of any point on the object at distance r from the centre of rotation
so v = ω(L/2) for one end, and v = ω(L/2) for the other end :wink:
tiny-tim said:
Hi Toranc3! :smile:v = ωr applies to the speed v of any point on the object at distance r from the centre of rotation
Hi tiny tim, thanks for replying.
So going back to angular momentum equation L=Iw, the omega applies only to a certain point of the rotation. Therefore when I substitute v=wr I am only replacing v/r=w at that certain point. So that is why I do not double it. Would it be correct to say that? The final answer is L=1/6mbv, forgot to add that in.
(try using the Quick Symbols box next to the Reply box :wink:)
no, ω is the same for every point of a rigid body
v is what varies :wink:
(ie the speed, v, is proportional to the distance, r, from the fixed point)
Well I am still not so sure why but I am going to put this error that I did in my head so I will not make the same error again. Thanks though
  • · Replies 17 ·
16K
