What is the magnitude of the torque exerted on the loop?
7 replies · 3K views
wadini
A rectangular loop consists of 101 closely wrapped turns of wire and has dimnesions .97m by .23m. The loop is hinged along the y-axis and its plane makes an angle of 70 degrees with the x axis.
A uniform magnetic field of .62 T is directed along the x-axis and the current in the loop is 3.1 A in the downward direction.
okay so for this problem I tried to apply the T=NIABsin() but that doesn't work...how do I go about this problem?
I have the radius=27.2
I can get the area by multiplying the dimensions
I have the current, I = 40 A
The Mag Field B=4.07 T
and 33 degrees
what do I do ?
Values given by you do not match with the given problem. In the problem the rectangular loop is given. From where did you get the radius?
oh sorry! that was not part of the problem. There is no radius given
okay so what I inititally did was T=NIABsin()
so I assumed there was only one loop so I plugged in T= (1)(3.1A)(.97*.23)sin(70)
and I got T=.4029385043
but that is not correct so what am I doing wrong? Am I just using the totally wrong equation? What am I missing?
why would I multiply the number of turns in the coil?
Also, I did that but I still did not get the right answer.
(101)(3.1 A)(.2231m^2)(.62T)sin(70)= 40.6967 N*m
is it correct that I use the equation T=NIABsin() ?
where N= 101 turns
I = 3.1 A
A= .97m * .23m
B= 0.62T
and sin()= sin(70) ??
