What is the mass of a black hole made of?
  • Context: Undergrad
  • Thread starter Thread starter kent davidge
    Black hole Hole Mass
The discussion centers around the nature of mass in black holes, specifically questioning what the mass of a black hole is composed of and the fate of particles from the progenitor star after the black hole forms. Participants explore theoretical implications, the relationship between mass and spacetime geometry, and the role of quantum mechanics in understanding singularities.
  • Some participants suggest that the mass of a black hole may not be made of traditional particles like neutrons and protons, but rather is a property of spacetime geometry.
  • Others argue that mass is a mathematical property arising from interactions with the Higgs field, distinguishing between different concepts of mass.
  • There are claims that particles from the progenitor star are destroyed upon reaching the singularity, but this is contested by others who point out that classical general relativity (GR) may not accurately describe what happens at that point.
  • Some participants raise the question of whether the Pauli Exclusion Principle is violated in the context of singularities, suggesting that two fermions might occupy the same state.
  • There is a discussion about the need for a theory of quantum gravity to better understand singularities and the behavior of mass in extreme conditions.
  • One participant notes that the mass of objects can be understood in terms of both spacetime geometry and the stress-energy associated with the particles that compose them.
Participants express a variety of views on the nature of mass in black holes, with no consensus reached. Some agree on the distinction between mass as a property of spacetime and mass as a result of particle interactions, while others challenge the implications of these distinctions.
Limitations include unresolved questions about the fate of particles in black holes, the nature of singularities, and the lack of a complete theory of quantum gravity to bridge classical and quantum descriptions.
This discussion may be of interest to those exploring theoretical physics, particularly in the realms of general relativity, quantum mechanics, and cosmology.
kent davidge
As the tittle says, what is the mass of a black hole made of? Would it be made of the neutrons (and protons, electrons) that formed the earlier star? If no, what happens to those particles? Where do they go to after the black hole is formed?
What is the mass of an electron made of?
Maybe I did not put the right words to describe my question. I think mass is not made of anything, but instead it's a mathematical property that particles have when interacting with the Higgs field.
May be you meant to ask what is the mass of i.e. what does the system with said mass consist of. The answer is that the mass is of the space-time, it can be vacuum no matter is needed. As to the question what happens to the particles, I don't think one can say much i.e. we don't know. By which I mean we don't know (except possibly for conjectures) what the consequences of the theory are. Singularities will form (i.e. there will be geodesicaly incomplete worldlines), but what type they are we don't know. We also don't know which particles will have such worldlines.
It's tempting to say that all the particles disappear down a black hole!
Oh Ok. What is the singularity from a math point of view? Metric assuming the value infinity?
In violation of several laws of physics? :smile:
kent davidge said:
1what is the mass of a black hole made of? Would it be made of the neutrons (and protons, electrons) that formed the earlier star?
The second statement of yours quoted above is easier to answer, so I'll start with that. "Mass" in the sense of what particles get via interaction with the Higgs field is not the same concept as "mass" in the sense of what appears as the constant ##M## in the spacetime metric of a black hole. The first concept is a property of particle interactions. The second concept is a property of the spacetime geometry. So it's important to keep the two concepts separate.
Given that, it should now be easier to see the answer to your first question. The mass of the black hole is a property of the spacetime geometry of the hole. It is not "made of" anything other than that. A better question would be, what causes that property of the spacetime geometry to be what it is? The answer to that question is: the matter and energy that formed the object that originally collapsed to form the hole.
According to classical GR, they hit the singularity at the center of the hole and are destroyed. Most physicists believe that is not what actually happens, because the laws of classical GR no longer work when the spacetime curvature gets strong enough, as it does close to the singularity. But we are not sure at this time what actually does happen in this regime.
Ok. So is it more correct to say that the Earth's mass, say, is a property of the ST geometry while our own mass is due particle interactions?
PeterDonis said:
According to classical GR, [the particles] hit the singularity at the center of the hole and are destroyed
In this case, the Pauli Exclusion Principle would certainly be violated, no? Dont we can use Quantum Mechanics to try to get an idea of what happens there in the singularity?
Why would you think that the exclusion principle might be violated?
Because in this case two fermions would occupy the same state... but by Peter Donis,
so, maybe, they are destroyed before occupying the same state?
You're still using a single word "mass" when you should be distinguishing different concepts. If by the Earth's mass you mean, for example, the ##M## that we deduce from measuring the orbital parameters of satellites, the Moon, etc., that is a property of the spacetime geometry. You and I also, in principle, affect the spacetime geometry around us, so we also have a mass in that sense, but it's much, much harder to detect.
If, OTOH, by the Earth's mass you mean the stress-energy associated with all the particles that compose it, that is due to particle interactions--at least, much of it is. There are also contributions from, for example, the kinetic energy of the Earth's atoms, because it is at a finite temperature, the pressure and stresses in the materials that compose the Earth, etc. You and I also have mass in this sense, of course.
So the simple answer to your question is that all objects have mass in both senses; it isn't a question of some having one and some having the other.
GR is a classical theory so it doesn't treat these aspects at all. Matter is treated as a continuous substance.
We could if we had a theory of quantum gravity. At this point we don't. We only have various speculative candidates.
Thank you
I think what you may have meant is what matter black hole is made of, just as Earth is made of several things as described here. I think it is a very interesting question one that I don't believe is so far answered in this thread but I am also curious.
Maybe one should ask where does the mass of a black hole lie. Of course black holes are made of pure spacetime and nothing else; but where exactly does this mass lie, since the matter from the progenitor star is gone and all is left is the singularity and other than that the properties of the spacetime geometry as driven by this new stellar object.
a singularity is the point where all physics laws break down.
For example in the Schwarzschild metric, there are 2 anomalies in the radial coordinate ##r=0## as a pure singularity and another one ##r=2M## but that's just a coordinate singularity.
The Schwarzschild metric is given by
##ds^2 = - \bigg(1- \frac{2M}{r} \bigg) dt^2 + \bigg( 1-\frac{2M}{r} \bigg)^{-1} dr^2 + r^2 d\theta ^2 + r^2 sin^2\theta d\phi^2##
Very interesting, so the only true singularity occurs at r = 0, but there are more than one coordinate singularity. What happens at these coordinate singularities? (Is it also unknown?)
A coordinate singularity just means you made a bad choice of coordinates for that region. There are coordinate singularities at the north and south poles, but there's nothing odd there in reality.
What is at the center of a black hole is called a "singularity" which means "the place where the math model breaks down and we don't know WHAT is going on". It certainly seems likely that whatever is there is broken down into elementary particles but we don't know that and likely won't until there evolves a provable theory of quantum gravity that may (or may not) let us figure out what is likely to be happening at the quantum level.
EDIT: OOPS. For some reason I thought I was responding to a new post and managed to miss the subsequent posts, so I've just duplicated what's already been said.
I appreciate your post indeed
Why don't we aswer the question by "The mass of a black hole is made of matter-energy compounds that formed it, whatever the matter made of due to particle physics"?
Because that doesn't address the issue of the multiple possible meanings of the term "mass". Nor does it address the fact that the black hole is vacuum.
Like Ibix said a coordinate singularity is just a bad choice we made.
But for the Schwarzschild metric which is a solution to the Einstein field equations and describes the vacuum outside of spherical mass distributions, the metric element contains two singularities ##r=0## which is an essential singularity like I said and ##r=R_{sch}= 2M## which is a coordinate singularity, where the escape velocity is that of light. Now this radius ##R_{sch}= 2MG/c^2## is called the Schwarzschild radius, but we often talk in geometrized units so ##G=c=1## and it becomes ##R_{sch}= 2M##.
This point is also known as the event horizon and it is what gives the term "black" in the name of the black holes. Since nothing can escape from that surface these objects appear black, because nothing is emitted. Later on Steven Hawking talked about the phenomenon where in the vacuum outside the black hole pair production happens, when a particle and its antiparticle are "born", so one of these particles gets sucked by the black hole and the other manages to escape and that is like the black hole emits radiation.
Oh ok. Thank you.
A comment about the "central singularity". One has to understand that it is a vague statement based on one particular case. The geometry inside the event horizon is very different from what euclidean intuition may suggests. So wording as the singularity at the centre may be misleading. The image it may bring, a point at the centre where something strange happens, is inaccurate. Also this is based on the Schwartzshild solution, in general the situation can be different. Even for the Kerr solution phrase "the singularity at the centre" is not just misleading it is wrong. In general, as far as I know and I might be wrong so if someone has references it would be great, very little is known. Penrose's theorem guaranties geodesic incompleteness if there is a trapped surface, but what kind the incompleteness it is no one knows.
Do the possibilities include the matter being converted to massless particles such as photons? Or perhaps that the energy is stored in a field with no particles at all? Perhaps other types of conservation (charge?, baryon number? ...) forbids those scenarios.
It always seemed to me that science should discuss the energy inside the BH based on the observation that it gravitates, and avoid any presumption about the form of that energy since we don't know for sure.
Classically, whatever falls into the singularity at ##r = 0## just disappears; it doesn't get converted to something else. The mass (meaning the ##M## that appears in the Schwarzschild line element) is not "stored" anywhere except in the geometry of the spacetime as a whole.
When we add quantum gravity to the mix, our current best guess is probably that whatever falls into the black hole eventually gets converted into Hawking radiation and is radiated back out. But that's only a best guess; we won't know until we have a good theory of quantum gravity. And even the best guess I just described isn't backed up by anything very strong; there are plenty of speculations in this area that can't be tested against each other experimentally, now or in the foreseeable future.
If the best guess I gave above is correct, then baryon number isn't actually conserved; it's only approximately conserved, and deep inside a black hole is one of the places the approximation breaks down. (Actually, it probably breaks down in the early universe as well; the fact that our universe contains more matter than antimatter, when it probably started from a state at the very end of inflation that was matter-antimatter symmetric, indicates that baryon number was not conserved back then. But that's another area where we don't really understand what's going on.)
Charge is conserved, but any black hole of significant size is probably going to be electrically neutral, just because if it happens to get some charge, by having charged matter fall into it, it will attract opposite charges which will fall in and neutralize it again.
An interesting popular physics account dealing with this phenomena
https://www.amazon.com/dp/0316016411/?tag=pfamazon01-20
I we can only guess right? Since it's impossible/hard(maybe hawing radiation?) to get any information from a black hole.
Hawking radiation doesn't tell you anything about what the stuff inside the BH looks like.
  • · Replies 22 ·
  • · Replies 51 ·
  • · Replies 22 ·
  • · Replies 24 ·
  • · Replies 44 ·
  • · Replies 40 ·
