What is the mass of a floating block of wood in oil and water?
To determine the mass of a cubical block of wood floating at the interface between oil and water, the block's dimensions and the densities of both fluids are crucial. The block, measuring 10 cm on each side, has its lower surface 2 cm submerged in water, meaning 8 cm is in oil. The relevant formula involves calculating the buoyant force, which equals the weight of the displaced fluids. The confusion arises from the total height of the fluids in the container, but only the submerged volume affects the calculations. Ultimately, the mass of the block can be derived from the buoyant force exerted by the oil and water.
laurenh19
i have a physics problem about buoyancy and could really use some help!
a cubical block of wood 10cm on a side, floats at the interface between oil and water with the lower surface 2cm below the interface. the density of oil is 0.6 g/cm^3 and the density of water is 1.00g/cm^3. what is the mass of the block?
it also has a picture that shows that the container is filled with 10cm of oil on top of 10 cm of water.
force=(density)(volume)(gravity)
i have no idea where to even begin!
If half the volume of the block was below the boundary (5cm below) the block would have a density half way between that of oil and water (i.e 0.8 g/cm^3). From the density you could easily calculate the mass, try using the same argument for the numbers in your question.
i'm confused on why they would say that the container is 10cm full with oil and 10 cm full with water...do i have to add that into my calculations somewhere?
so far I've come up with
mass=(0.6g/cm3)(8cm)+(1.00g/cm3)(2cm)
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
