What is the Maximum Angle for Total Internal Reflection in a 30-60-90 Prism?
The problem involves a 30-60-90 prism and the conditions for total internal reflection of light entering the prism from air. The original poster seeks to determine the maximum angle of incidence for which total internal reflection occurs at the horizontal face of the prism.
  • Participants discuss the use of Snell's Law and critical angles to find the maximum angle for total internal reflection. There are questions about the relationships between the angles in the prism and how to apply geometric relations.
Some participants are exploring the relationships between the angles and the geometry of the prism, while others are questioning the assumptions made regarding the indices of refraction and the angles involved. There is a recognition that further clarification is needed regarding the calculations and the specific angles referenced.
Participants note that the problem requires understanding the geometry of the prism and the conditions for total internal reflection, which may not be fully clear to all involved. There is also mention of the need to consider the correct index of refraction for the glass in the prism.
Gclip5
Red light is incident in air on a 30o - 60o - 90 o prism as shown. The incident beam is directed at an angle of φ1 = 37.6o with respect to the horizontal and enters the prism at a height h = 26 cm above the base. The beam leaves the prism to the air at a distance d = 73.1 cm.
What is φ1,max, the maximum value of φ1 for which the incident beam experiences total internal reflection at the horizontal face of the prism?
http://imgur.com/hJ5oid3
Snell's Law : n1sin(φ1) = n2sin(φ2)
geometric relations of a 30-60-90 triangle
I used what I got for my n of the triangle, which is correct, at 1.289, and got a critical angle using the fact that for total internal reflection, the angle must be 90 so i got φ = sin^-1(1/1.289) which equals 50.877 degrees. My problem lies within the geometry of the situation, I've tried adding/subtracting all combinations of 90, 60, and 30. I can't seem to get what the φ1, max would be though.
Does that help?
Sort of... I assume the 2 and three have nothing to do with the φ2 and φ3? I don't get exactly what to get with them. Like i understand 3 would be 50.877 degrees right? And that 2 is the actual φ1 I need, but I don't get how to find the angle underneath 2 because if i get that one can't i just solve for 2?
3) is what is termed the incident angle, the angle of the incident ray with the normal at the interface. 1) is the angle of the slope of the interface, a given. 2) is the angle of the incident angle with the horizontal. The three angles are related, so if you know any two of them, you can easily find out the third.
Is this where you are stuck?
Yeah that's exactly where I'm not sure how to work them. I only know one of the three, the incident ray. RIght? Because when i use the critical angle calculation that's the angle I am getting.
You always know 1). You know 2) or 3) depending on which part of the problem you are on. Now, 1) + 2) + 3) = ? Look at the diagram.
OHHHH, so the first angle is 30, and if I know the angle of incident, then i can just do 90 - 3) - 30 = 2) right? If I do that with the angle of incident i got (50.877 degrees), then I still don't get the right answer.
But that is something else. You have not shown how you got 50.877 degrees, so I cannot comment on that.
Ok I'm using Snell's Law, n1 = 1 (its in air) and n2 = 1.289, if total internal reflection is required, then you can solve for the incident angle by φ = sin^-1(n1/n2). When you plug in n1 and n2 you get 50.877 degrees.
The problem wants total internal reflection at the horizontal face of the prism. So ##n_1## must be that of glass. And the angle you will obtain will be that with the normal to the horizontal face, i.e., with the vertical. So you need quite a bit more effort to get the answer.
10K
11K
11K
9K
  • · Replies 16 ·
