What is the Maximum Magnetic Field Under Overhead Power Lines?
2 replies · 3K views
Angie K.
You want to get an idea of the magnitude of magnetic fields produced by overhead power lines. You estimate that the two wires run about 30 m above the ground and about 2.9 m apart. A call to the local power company provides the information that the lines operate at 10 kV (rms) and provide a maximum of 44 MW to the local area. Estimate the maximum magnetic field you might experience walking under these power lines.
B=mu0*I/2 pi r
Would I be able to find the current from the given power and voltage?
Power = V^2/I where V is the voltage (10kV) and I is the unknown current and power is 44 MW
Then using that to find the magnetic field
B=mu0*I/2 pi r
and I'm not sure which value for r to use? Would it be 2.9m/2 because it's the radius I'm interested in?
Thanks in advance!
B=mu0*I/2 pi r
The formula for the power is wrong.
B=mu0*I/2 pi r
Thanks in advance!
You are interested in the magnetic field at your place, on the ground. How far are you from the power lines?
Remember you have 2 line with current traveling in opposite direction. There will need to be a vector superposition of the two lines' currents.
