What is the Maximum Mass that Can Be Hung Before the Block Moves?
  • Thread starter Thread starter Destrio
    Friction Tension
The problem involves determining the maximum mass that can be suspended from cords connected to a block resting on a table, considering the effects of friction. The subject area includes concepts from mechanics, specifically forces, tension, and friction.
  • Participants discuss the calculation of frictional force and the setup of equilibrium equations for the forces acting at the connection point of the cords. Questions arise about the relationship between horizontal and vertical forces and how to express them mathematically.
Participants are actively engaging with the problem, with some providing guidance on setting up equations for equilibrium. There is a mix of attempts to clarify concepts and calculations, with no explicit consensus reached on the final approach.
There is mention of a potential confusion regarding the angle used in calculations, indicating a need for careful attention to detail in the setup of the problem. The original poster expresses uncertainty about the next steps after calculating the frictional force.
Destrio
Hey,
I so far haven'y encountered a problem like this yet and don't know where to begin.
An object of mass, m , is suspended by two cords connected to a wall and to a 50 kg block resting on a table as shown. A coefficient of friction on 0.47 exists between the 5.0kg block and the table. What is the maximum mass, m , that can be hung from the cords before the 5.0kg block begins to move?
So far all I have been able to get is
Fnet = 0 due to no movement
and
Ff = uFn
= (0.47)(5.0kg)(9.8m/s^2)
= = 23.03 N
Where do I go from here:
Image: http://img85.imageshack.us/img85/3025/physicsfrictionib5.jpg
The first step is done - you calculated the friction force. Now, the maximal force in the horizontal string must equal the frictional force, right? So, you must set up the equations of equilibrium for the point (node) where the three strings meet.
Analyze the forces acting at the connection point. Vertical and horizontal forces must each add to zero. Hint: Call the (unknown) tension in the upper cord T and set up two equations.
Hey
So would the horizontal force on the right rope (Fx) be equal to the Ff , 23.03N?
and the Fy be 14.39N?
if so, how do I use this to determine the mass?
Yes. The max Fx allowed will be the frictional force acting on the 5kg block. You now know that the tension of the string connected to the wall and connection pt does have a vertical pulling force and rightward pulling force. If the max allowable rightward pulling force is given by friction, are you able to find the upward pulling force by the tension of the string connected to the wall and connection pt? That upward force will be equal to ur max weight allowed by ur mass right?
I'm confused,
could you show an equation (or some of it) showing what you mean please?
As said above, set up the equation of equilibrium for horizontal compoments at the connection point first: -T_{1} + T_{2}\cos(180 - (90+23))=0, where T1 is the tension in the horizontal string (which equals the frictional force), and T2 is the tension is the string connected to the wall. Then, set up the equation of equilibrium for the vertical compoments: T_{2}\cos(23) - mg = 0. Since you calculated T2 in the previous step, I'm sure you see how to get the mass m now.
thanks!
I figured it out :)
I was thrown off for a moment when you put cos 23 (should be cos 32) but that helped me solve it
thanks very much
EDIT:
sorry, I didnt realize i wrote the wrong value on my diagram, my mistake
