What is the maximum potential energy of an oscillating mass?
The discussion revolves around a physics problem involving a 2-kg mass attached to a spring undergoing simple harmonic motion (SHM). The original poster seeks to determine the maximum potential energy of the mass based on its speed at the equilibrium position.
  • Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants explore the relationship between kinetic energy (KE) and potential energy (PE) in SHM, questioning values at the equilibrium position and maximum displacement. Some discuss the conservation of energy principle, while others express uncertainty about the implications of their calculations.
There is an ongoing exploration of the energy relationships in SHM, with participants attempting to clarify the roles of KE and PE at different positions. Some guidance has been offered regarding the conservation of energy, but no consensus has been reached on the maximum potential energy value.
Participants mention the urgency of an upcoming exam, which may influence their requests for clarity and understanding of the concepts discussed. There is also a focus on the assumption that total energy remains constant throughout the oscillation.
lussi
1. Homework Statement
A 2-kg mass attached to a spring oscillates in simple harmonic motion and has a speed of 5 m/s at the equilibrium point. What is the maximum potential energy of this oscillating mass?
2. Homework Equations
I know that the potential energy is: Ep = 1/2 kx2
k = mω2
In SHM,
KE+PE = Constant.
At the equilibrium position, the PE is what value? Once you have that then at the max position of the spring, the KE is what value?
So, at the equilibrium position KE = PE, therefore KE = 1/2 mv2 = 25 J. And PE = 25 J. If that's correct. But I don't know what will be the value at the max position
Not that KE= PE. It is that KE+PE= a constant. So, you can (for example), find all the different energies at the equilibrium and then find all the energies at your maximum potential. And then you know that they must equal the same constant (in the end you should only have max PE which you don't know).
I really don't know how to do it, and I have an exam tomorrow. If you tell me the solution, I might find the logic by looking at it.
KE +PE = Constant
At the equilibrium position you found that PE=0 so that KE = Constant = 25 J
Therefore
KE+PE = 25
At the maximum positionm what would be the KE? (when the spring is oscillating after it reaches its max position does it keep going or does its velocity change?)
Since KE + PE = const, and at the equilibrium position PE = 0, therefore KE = Constant = 25 J, as you rock.freak667 said. And since "they must equal the same constant", as Jufro said, that means that at the maximum position KE = 0 and PE = const = 25 J. Is that correct, or am I mistaken again?
Yes that is correct. So PE=25 J at the max position.
For SHM KE+PE = constant at any point in the motion
Thank you very much :)
  • · Replies 21 ·
