What is the maximum solution for the given differential equation?
mathboy20
Dear Friends,
Given the differential equation
[tex]\frac{1}{1+x^2} \frac{dx}{dt} = \frac{\alpha \cdot 2 \pi}{4} \cdot cos(t)[/tex]
with the condition that x(0) = 0
Then find the largest possible solution (this is how its stated) if either
[tex]\alpha_{1} = 1/2[/tex]
[tex]\alpha_{2} = 1[/tex]
Don't I treat the above as a seperable differential equation?
Such that
[tex]{(\frac{1}{1+x^2})}^{-1})} \frac{dx}{dt} = {({\frac{\alpha \cdot 2 \pi}{4} \cdot cos(t)})}^{-1}[/tex]
[tex]1+x^2 dx = \frac{2}{\alpha \cdot \pi \cdot cos(t)} dt[/tex]
[tex]\int x^2 dx = \int \frac{2}{\alpha \cdot \pi \cdot cos(t)} -1 \ dt + C[/tex]
[tex]\frac{x^3}{3} = \frac{2 \cdot ln(\frac{-cos(t)}{sin(t)-1}- \alpha \cdot \pi \cdot (t-C)}{\alpha \cdot \pi}[/tex]
[tex]x^3 = 3 \cdot (\frac{2 \cdot ln(\frac{-cos(t)}{sin(t)-1}- \alpha \cdot \pi \cdot (t-C)}{\alpha \cdot \pi})[/tex]
[tex]x(t) = (3 \cdot (\frac{2 \cdot ln(\frac{-cos(t)}{sin(t)-1}- \alpha \cdot \pi \cdot (t-C)}{\alpha \cdot \pi})^{\frac{1}{3}}[/tex]
if I then insert x(0) = 0.
I get C = 0. Then this means that max solution is 0??
I just want to be sure. Can anybody please look at my result at then inform me. Have done this correctly?
Thank You in Advance
Fred
[tex] \frac{1}{1+x^2} \frac{dx}{dt} = \frac{\alpha \cdot 2 \pi}{4} \cdot cos(t)[/tex]
[tex]\Rightarrow \frac{1}{1+x^2}dx=\frac{\alpha \cdot 2 \pi}{4} \cdot cos(t) dt[/tex]
Now just integrate both sides.
I then get
[tex]tan(x)^{-1} = \frac{\alpha \cdot 2 \pi}{4} \cdot sin(t)[/tex]
I then take arctan on both sides of equation to arrive at a solution? with regards to the two alpha's?
mathboy20 said:
I then get
I meant to I take tan on each side of the equation, and thusly obtain x(t) = ??
and then by choosing either alpha1 or alpha2 see which of these gives largest possible solution?
mathboy20 said:
I then get
You mean tan-1(x) or arctan(x). There is no need to solve for x(t). Just differentiate with respect to [itex]\alpha[/itex] to find a maximum.
Dear Mister Hallsoft,
Just to be clear I find the derivative with respect to alpha of the original expression
[tex]\frac{1}{(x^2+1)} dx = \frac{\alpha \cdot 2 \pi}{4} \cdot cos(t) dt[/tex]
[tex]\frac{-2x}{x^4 + 2x^2 +1} = \frac{\pi \cdot cos(t)}{4}[/tex]
and then insert the two alpha values to obtain the maximum??
Best Regards
Mathboy
