What is the Meaning of Gradient in Linear Slope?
  • Thread starter Thread starter mister_jang
    Gradient
The discussion revolves around the concept of gradient in the context of linear slopes, particularly focusing on its mathematical definition and interpretations. Participants explore the relationship between gradient, angles, and trigonometric functions.
  • Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the definition of gradient as the ratio of change in y over change in x, questioning its meaning in various contexts such as speed and acceleration. There are inquiries about the relationship between angles and the gradient, particularly regarding the interpretation of inverse trigonometric functions.
The conversation includes attempts to clarify misunderstandings about the gradient and its applications. Some participants express gratitude for corrections and insights, while others continue to seek clarification on specific points, such as the meaning of angle measurements and their representation.
There are indications of confusion regarding the relationship between angles and their representations, as well as the distinction between gradient and specific applications like speed. Participants acknowledge gaps in their foundational understanding of the concepts being discussed.
mister_jang
Gradient as many knows is rise/run or the ratio between the change of Y over change of X
However, what's the meaning then?
It has no significant true meaning to a linear slope, the only true meaning is
- when i inverse tangent O/A(the gradient) ( right hand side of the picture ) i get the hypotenuse
- when i inverse sine O/H which i do not know the meaning ( left hand side of the picture ) i get the hypotenuse
Thanks in advance, did appreciate the help
If you really mean "what is the gradient of a line" (in the United States we would call it the "slope") it is exactly as you have defined it: "the amount y changes, with a certain change in x, divided by that change in x". That is just saying that it is the rate of change of y with respect to x. That has a specific meaning only when you give meaning to x and y. If x is, for example, time, and y is distance so that y(x) tells you far you have walked or ridden by time x, the gradient of the line is the "rate of change of distance with respect to time" which is just your speed. If y is your speed while x is still time, then the gradient is the rate of change of speed or acceleration.
But I can make no sense out of your "when i inverse tangent O/A(the gradient) ( right hand side of the picture ) i get the hypotenuse". No, you don't. The inverse of a trig function gives an angle- the measure of the angle at the lower right vertex. In this example, "O", the length of the opposite side, is 3 and the adjacent side is 4 so "O/A" is 3/4 and the arctan of 3/4 is the "36 degrees, 24 minutes" you have in the picture. The length of the hypotenuse is, of course, 5.
Firstly, i would like to thank you for the reply =)
Secondly, thank you for rectifying my ignorant with regards to the inverse matter
Thirdly, thank you for helping me understand the gradient is seemingly the measurement of the speed
However, the 24 minutes represent the 36 degrees which isn't the 24 minutes a value of the X axis?
And what does the 24 minutes means then?
Sorry, just realized i have a very weak basic which i need to make clear
Regards
You seem to have some massive misunderstandings. "speed" is one application or interpretation of the gradient. It is NOT correct to say that the gradient itself is "speed". That was one reason I also gave "acceleration" as an application of a gradient.
Further, I am puzzled by "the 24 minutes represent the 36 degrees which isn't the 24 minutes a value of the X axis?". Perhaps this is a language problem. No "24 minutes" is not value of the X axis. Nor does the "24 minutes" 'represent' the 36 degrees. In fact, doing the calculation I should have done before, the "24 minutes" that I copied from your picture is wrong! The arctangent of 3/4 is approximately 36.870- that is 36 degrees and .870 degree. There are, by definition, 60 minutes in a degree so .870 minutes is (.870)(60)= 52 minutes, not 24. The angle is 36 degrees 52 minutes, not "24". The "52 minutes" (not "24 minutes") is part of the angle just as if a length were given as "4 meters and 23 cm." the "23 cm" would be part of the length measurement.
Oh all right, so the minutes itself is a representation of the decimal
And that the gradient is simply just a measurement of the slope
And does the 36 degrees 52 minutes a representation of something else or its just an angle that's all?
Thanks again =)
As Hallsofivy said, 36 degrees 52 minutes is just another representation of 36.87 degrees, so yes, it's all just an angle.
All right thanks =)
  • · Replies 53 ·
  • · Replies 19 ·
